The 5R6 as well as the lytic zobel seems to have snuck in there as well. Prolly soldered them all same time. Bit optimistic with those sinks but they were supposed to bolt into an alu case.
Burning them now. Bit iffy results. The fixed VR is 3k6 and trim is 1k. They seem to have been built for +/- 18. Trim @ 0 gives 16,5 v. Its the same 5R6 as current limiter, but only 3 greens. And they take way different current.
The CSS probably works, and I can adjust the Vouts. 12.2 volts over R103/203 3K6 gives 3,39 mA and is probably legit. I tried to measure Vdrop over the 3 greens but got no readings. Maybe I can do it when not running. It must be very badly matched, although that doesnt sound like me
Thanks, Ill kick it up again after reassembly. I also re-established the masterclass in complicating things. I switched caps MKT/Lyts when I was over it. Now ofc I cant fit the *** allen screws
