Hello!
Anyone has built speaker cabinet with spruce wood? What is the thickness did you try?
Thanks!
Thanks!
Wood | tangential | radial | longitudinal | |
spruce | 0,33 | 0,16 | 0,01 | |
pine | 0,29 | 0,17 | 0,01 | |
oak | 0,35 | 0,20 | 0,01 | |
beech | 0,45 | 0,22 | 0 |
So 1" thick should be safe?Hmm, spruce MOE = 550 ksi (0.789 m psi)
'Our' typical ~0.75" no void BB plywood MOE = 1.8 m
0.75*(1.8/0.789)^0.33 = ~0.9846" (~25 mm), so 1" thick works for me and* as long as the Maple is no void.
What do you think of spruce ply?Spruce is a very good wood for loudspeakers. It’s light and strong, and when properly dried is very stable. You may want to make your box fronts and sides a little thicker, 1” or so, than you would with a hardwood like oak or maple. I like spruce, I think it’s underrated as a furniture wood. If quartersawn it will be exceptional in appearance and strength per weight. Having said that, you can make great loudspeakers from Home Depot studs if you have the time.
Birch is totally different compared to poplar plywoods.and it doesn't matter so much witch kind of plywood as long as it is decent quality. and no or allmost no air gabs inside
