no mercy simulator killer circuit
Thread title borrowed from Nelson Pass.
https://www.diyaudio.com/community/...rtion-killer-circuit.24192/page-5#post-296714
I know that simulations are neither accurate, nor reliable, nor credible, nor are the results achievable in reality, nor [add here what you like]
My simulation results in Microcap12 before 1 month looked like this:
Conditions: Bias 1.5A. Load 8 ohms. Peak power. THD @1kHz
1k: -208dB should translate into 0,000000008 %
I started to become suspicious because THD was already flat until 30W or so...
In the past, when the circuit was not so refined, distortion was always constantly rising with power, starting at -180dB at 10mW power.
So I simulated the sine source alone, with 1000k load resistor: Flat line at -208dB
Now the question: Something wrong with my settings ?
Or is the simulator limited by the bit depth of the sine source ?
24 bit would translate to -192dB.
Disabled Account
Joined 2002
Or...don't simulate at all (the zero software license model) and just calculate, build circuits with real life parts on real PCBs and measure circuits with non virtual instruments. It is a question of getting accustomed to but then it works not only on a screen but also in real life with real life numbers!
Reactions: 1 users
Those low distortion/noise numbers only live inside a computer.
Real world numbers are dominated by self noise and even linearity of passive components.
Check the performance of the best audio analyzers like the Audio Precision and they can not get more than -115dB or so for their top models.
As an example, you can calculate the self noise of an 1K resistor at 25 degrees Celsius and you will get something like -120dBV, if I recall it correctly.
By the way, I think simulation is a great and necessary tool and I am a PSpice user myself, but there are limits and common sense to be considered, too.
Reactions: 1 users
Sure, simulation is not replacement for assembling a real prototype, it only helps to shorten the development time making is faster and cheaper.
At the end you need to assemble and measure a real prototype, or you will run into crazy conclusions as the numbers mentioned above.
Reactions: 1 user
Neurochrome.com
Joined 2009
Depends... Few have the ability to measure THD below about -110 dBc, so there is that. I also find simulations very helpful in separating the wheat from the chaff. If a circuit is fundamentally broken it will usually simulate like crap. If a circuit performs reliably well in the simulator there's a pretty good chance it'll also work in the lab. It's a lot easier, cheaper, and faster to change R from 100 Ω to 120 Ω in the simulator than it is to do so in the lab.
I seem to recall that the THD+N for the APx555 with the precision analyzer enabled is -125 dBc or thereabout. Mine reaches down there and hits -148 dBc on the THD alone.
Tom
Reactions: 1 users
-120 decabel? Wow, that's -12000 dB!
Seriously, THD+N is something else than THD and the distortion floor of a simulator is dependent on accuracy and time step settings. Usually reltol is the most important accuracy setting. When the simulator has strobing, which most don't, you can force it to calculate precisely at time points that you later want to do a DFT. If not, you can just play with the maximum time step.
