just this Mod for this 3255 board??I bought this TPA3255 Board.
Four capacitors beside heatsink are series-connected 4700uF/25V.
So a total of 4350uF capacitance is embedded.
It's not a good idea from the point of view ESR.
By the way, another complaint...
The speaker output makes a pop noise during Power-up and Power-down. So I developed an automatic reset control circuit.
This can eliminate pop sound without manual reset switch control operations.
Hope this will help you easier.
CyberPIt
我看见了你这个在中国淘宝上卖的板了··不知道你是多少钱买的?
I saw your board sold on Taobao in China... Don't know how much you bought it?
Yes i could use 12S but i find better and cheaper charger for 13S thats why i actually want to use 13s. I have step up converter 500W from wondom. But it does use 12W in idle mode. therefore its not very efficient. i want to get most out of batteryJust change to 12s and you should be ok. You can always use a combo that gets about 12v and then go to a DCDC step up to get regulated 51.5v even as cells drain and voltage changes. I have used the 10A (red PCB) DCDC units from Aliexpress (shown earlier in this thread) with success. I ran it from 12v Pb-acid UPS backup battery.
i know 53.5V on 6ohm. i will use 4ohm driver. but the specs does also say, that it can handle 69V (or 63V) before damage. so i wonder i can use 54.6V for short term before battery start loose its max current...TPA3255 max voltage is 53.5v (as per TI). I am not sure of your use case, but it would damage the IC if you are running it above the specified voltage. I would suggest to limit the voltage to 50v top.
Did you run it successfully at 54.6V? i want to do same...Hi, this is my first post and I am a newbie on diy audio. Sorry if this is not the right place to ask. I want to use tpa3255 amp for a off the grid sound system.
I planned to use a 13s lithium battery ( 48v nominal) 54.6V fully charge as power supply. Is it safe to run this amp at that voltaje? I read is some thread don't remember where that there were problems even at 48V.
I planned to use this battery because it is very easy to find from electric bikes.
my board is coming.. i'll follow your mod 😆Sound-related modification is yes.
Other modifications are adding LED drivers for CLIP(RED, pin21), FAULT(BLUE, pin19), and GVDD Power(GREEN).
hi,hansueliI just changed fake NE5532 for original NE5532. I think some changement on Bass and High adjustment are the result.
My DC-DC converter dont Step-up... I don't know why.
But amp is really good. After this changment and with the true capacitor size its one of the best china amps.
:-D
