[insert your name]
name your sub
Introduction
One paragraph or so here to summarise your project.
Design Goals
Describe your room - solid room with lots of room gain? small room? large room open to other rooms?
Approx room size - in ft and metres
Describe your goals - what aspects of performance where important - SPL targets, extension, accuracy, low distortion, etc.
Describe your use - home theatre, music - classical, doof doof, RNB, pop, rock ...
Design Decisions
What are some of the key decisions you made and why did you make them?
Did you simulate? What program did you use?
Have you measured it?
How have you integrated it into the rest of the system (filters, bass management, etc)
Have you used eq to deal with room modes or room gain?
Details
Net box volume: (L/cu ft)
Materials used:
Box dimensions: (mm/ ")
Weight: (kg/lbs)
Amplifier: $cost brand & model
Driver: $cost brand & model
You might like to mention construction, bracing, vent design, etc.
You may like to give credit to good service received from suppliers.
Evaluation: how does it sound?
How does it compare to other subs you have heard? What other subs have you heard?
What are the limits of this sub? Does it sound better when crossed below 40 Hz?
insert other heading here if required
If you wish to add anything that doesn't fit elsewhere.
Conclusion
Do you recommend others build something similar?
What would you do differently?
Credits
Did anyone help with the design?
[add a link here] Other subs that inspired this design?
