Best Compression Drivers today 2022?
Administrator
Joined 2004
would you mind ranking the multicells also?
The metal Altec 1505 is my favorite. I thought the wooden ones would be better, but they weren’t. However they were listened to in very different systems, so I can’t say for sure.
The 1505 in a medium large space is amazing.
I like the tar filled 1005, followed by the normal 1005. Damn the tar filled are heavy! The 803 was nice and I still use it for PA duty, but for a home system the 1005 worked a little better. Not night and day of course, it was just easier to get the 1005 where I wanted it.
Cal Weldon has a pair of 1803 that I would love to hear. I’ve seen them and they are huge, but Cal didn’t have them running at the time. Would they sound like the 1505 only bigger?
  • Thank You
Reactions: 2 users
Thank you very much @Pano !
I have a pair of wooden 1505 replicas myself, so I was hoping those would come out on top :) But like you say, this may very well be system and room dependant. I guess the metal ones may be more 'lively', I have never heard them. I like the 1505's very much, best midrange I have ever heard! However I find them best crossed over far lower than the 7khz Jean Hiraga and many others use. Like 3-4khz. They seem 'muffled' to me above this frequency, and less detailed than a tweeter horn taking over from 3-4khz.
I agree, the 1803's would really be something to hear :) I think the multicells are pieces of art, they look so cool!
Reactions: 1 users
which Faital model ? you seems a Faital boy did you try the new HF1460 i have the 1inch HF108 but i would want to go lower 900 /1K with a 1.4 driver
I have used the HF10AK, 108, 108R the HF1460 is on its way.
The HF10AK that i use in a 3 way design is crossed over at 4k and has the same sound signiture as the TAD BE compression driver, just not quite the same efficiency. They are really very sweet drivers.
I have used and tested many 18 Sound, RCF, B&C Comp drivers and none of them were as detailed and sweet sounding.
The waterfall from HF1460 looks really good. But the HF1440 seems able to cross a bit lower.
What frequency are you planning to cross on HF1460?
i have a SEOS 18 1.4inch so i will try 900/1K , i have FR 6.5inch cone driver so i can cross where i want , with the HF108 i was a 3K 12db i will see if i will still need it with the 146O
only if the Cat will let his place to put the horn
:D
Reactions: 1 user
Looking forward to your result.
I'm currently considering buying compression drivers and have been impressed by the HF1440, HF1460, DCX464, and ROSSO-65CDN-T models.
However, I'm also interested in hearing from users about the performance of the DCX354.
If anyone has experience with this driver, I would appreciate hearing their thoughts.
