12VRMS * sqrt(2) = 16.97V peak (+16.97 to -16.97)
minus 2 diode forward voltage drops @ 0.7V each --> 15.57V peak
minus peak-to-trough ripple voltage --> about 15V trough voltage
minus LM317 / LM337 input-to-output voltage drop (a/k/a "dropout voltage") --> about 12V DC
12VRMS * sqrt(2) = 16.97V peak (+16.97 to -16.97)...
Thanks for the math, Mark. I appreciate the actual details!
NOOOOOOOOOO!shipping date updated to December 21.
To the alternate parts we must go.
Webpage still showing:shipping date updated to December 21.
Available for back order
More stock available to supplier lead times which is approximately 9/25/23
Does Newark have a clue? My experience, No.
I have these parts on backorder also.
Does the VRDN have enough juice to power TWO of the the BA 2018 line stages? I've stuffed (but not tested) two boards for a symmetrical balanced version, hence the question. If need be, I could use two VRDN supplies, powered off a sufficiently beefy transformer, but that'd mean building another one of those, too....
Batteries produce DC. The VRDN takes AC and produces DC.Can I use battery for this power supply ?
VRDN: bipolar regulator PCB for line level ckts: ±11V to ±20V @ 1.5A with "De-Noiser"
Let me rephrase that for you:
Is 1.5 amperes enough juice to power TWO of the BA 2018 line stages?
@rikiheck
If you search the original WBA18 thread, I had mentioned the current draw of this circuit. And yes, it is exactly as 6L6 states. Needless to say, 1500mA supply capability is more than enough. As a general rule, most of these small line level discrete circuits and also opamp circuits don’t draw much power so the VRDN has likely universal compatibility.
Best,
Anand.
Best,
Anand.
I've made a VRDN PSU but it did not make stable output with onsemi 317, 337 and a toroidial transformer 25VA 18-0 dual secondary.
It happened also with connecting the jumpers of bypassing denoiser.
Did I make any mistaks?
I wouldn't worry too much about a $50 multimeter whose displayed output voltage flickers between 18.00V and 17.99V. But if you remain deeply, deeply concerned/worried, you could (A) load the outputs with resistors-to-ground which draw approximately the same current as your final audio gear will draw from VRDN; and also (B) monitor the output waveform with an oscilloscope instead of a multimeter.
For example, if your application calls for VRDN to deliver 25mA to the left channel +18V supply, and another 25mA to the right channel +18V supply, that's a total of 50mA from VRDN's +18 output. Ohm's Law tells us that a 360 ohm resistor has the same current draw {math: 18V = 0.05A * 360 ohms} so if you've got a 330 ohm or 390 ohm or 360 ohm resistor, connect it between VRDN +18V and ground, to achieve a same-current load.
Unfortunately, it's near-on impossible to find such a thing in a thread with nearly 4000 posts.@rikiheck
Part of the reason I asked is that, e.g., the XP-20 is said to draw about 25W. That's an order of magnitude greater than the BA 2018. Out of curiosity: Where is all that power going?Nowhere near 1500mA. I think it’s closer to 60 or 80mA per board.
- Power Supplies
- VRDN: bipolar regulator PCB for line level ckts: ±11V to ±20V @ 1.5A with "De-Noiser"
