Can someone provide a quick comparison, pros and cons between the CDSP6x8 and the 4x10HD.
Application will be a 4 way stereo hifi speaker crossover with twin woofers plus mid and tweeter. Ideally I would use the output channels for crossover and to remove peaks/dips to get a 30hz to 20khz flat response (anachoic) and then use the input channels to tailor sound to room/taste. Source will be either Chromecast audio direct into digital input or via an Audio GD DAC into an analogue input.
All comments welcome on these or alternative minidsp products. Thanks in advance.
