@abraxalito it's necessary R2 or in your simulation is the output impedance of the source?
R2 is the source (ESS DAC's) output resistance yes. The filter does need to be driven from that source impedance. If you have a source with a lower output resistance then include a series resistor to get to 195ohm.
Good idea, I'm unfamiliar with it. I would guess its a logic gate giving you the DSD out. I would suggest adding your own flip-flop with a very low impedance power supply. Perhaps the DIYers on the 'no DAC is the best DAC' thread will have some suggestions?
The schematic is sheet 1 of 2. Looks like the DSD output header/connector is on sheet 2 as I can't find it on this sheet.
Sheet 2 can be the attached now?
Amanero output impedance 50 ohms but I have between the Amanero and the 4th order LC filter the DIYINHK Amanero I2S isolator Free Amanero Isolator bare PCB Twin pack - DIYINHK, the output impedance is still the same like the Amanero?
- Digital Line Level
- low pass filter for DSD
