Hi.
A few pics of our tribute to the boombox found here...
http://www.diyaudio.com/forums/multi-way/148807-transmissionline-ipod-docking-station.html
We've a way to go yet but it's basically a smaller version. Same Peerless full range drivers.
I think this may be similar to a cube I was designing to be a folded tabaq.
http://www.diyaudio.com/forums/full-range/88787-tabaq-tl-tang-band-41.html#post3218664
Use polyfill stuffing from closed end to a little past the driver. Some people go as far as 2/3rds from the closed end. Experiment but don't overstuff or you will get very little bass. I see you have a removable front panel so it may require adjustment to get the best sound. From seeing how big your box is, I would guess 10 to 20 grams per side of of polyfill would be a good start.
thx xrk.
I've bought some *low* density foam...
Upholstery foam Sheets. Select grade & size & depth. High, Medium & low density | eBay
Will that do?
Adri
Will that do?
Adri
