Is this board available?
Regards Christian
USB-I2S up to 384KHz
Sirs,
Is a Wave I/O USB module compatible with this configuration as the amero USB PCB is? I.ie a " drop in replacement" (sorry if I am missing anything obvious)
Cheers
Johnny
Amanero Technologies
Here are details about it.
Thanks Kevin
Thank you for the Kivin...looks very nice, link, I posted as I already have a wavevI\O pcb ( sorry I did not mention that bit) but am not sure if a a wavevI/o is a drop in replacement...or would I have to purchase Amero?.
Also whilst where spending money
...would a Lampizator Amber DAC kit be a good option ( with RHopoint resistors?) as an tube tube output?..any one tried this combo??...soon be Christmas eh!!![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Cheers
johnny
Cheers
johnny
WaveIO is not a drop-in replacement for Amanero, but it could easily be connected to my input board using u.fl connections (the small round connectors labeled I2S DATA, LRCLK and BCLK). You would also need to supply 3.3VDC power for the DAM1021 isolators. I have not checked it the isolators can tolerate 5V supply. If they do, then you could use the 5V supply from Waveio board for that purpose.
Normundss,
Do you have any of your boards still available by any chance?
Yes, I still have some.
I am out of boards at the moment. Since Soeren has indicated the new firmware will be released Real Soon Now, I will wait until the release before ordering another batch.
There may be some layout adjustments to make convenient connections for the new DAM functions. I am also thinking of adding an I2S input selector to allow switching between two I2S sources.
I would like to get a feeling for the interest in new features:
1) Selection between two I2S inputs
2) Convenient connectivity for true balanced setup using two DAM1021 DACs. (If the new firmware supports it)
3) Convenient connectivity for chaining several DACs for active crossovers (if the new firmware supports it)
4) other suggestions?
Thank you norumduss.. That's very usefull info.
I am still pondering a Lampizator AMber DAC kit as an output stage, anyone tried this?
Johnny
http://www.diyaudio.com/forums/digi...ii-black-builders-thread-115.html#post4329692
You'll have to use low gain tubes and adjust cathode resistors in order to lower the gain.
Tibi
Anybody else experienced a problem with Hifiberry Digi on the Toslink input? DAC doesn't seem to lock the signal. Tested with both ORJ-5 and TORX-147L. Toslink is working on my AVR though. 3.3V are present.
Fabian
I have had a problem with a cheap toslink cable not fitting well into the receiver socket and loosing the signal when touched.
Do you have another Toslink source and cable to try ?
- Group Buys
- Input and switch boards for Soekris DAM1021 DAC
