Edit Aug 11, 2020: annotated BOM in MS Excel format here.
Announcements & Updates: I have been getting a lot of reports of builders experiencing sparks with connecting the power supply or melting the power switch at first turn on. Please make sure your MOSFETs have an insulator pad and insulator washer/bushing around the screw head. Check for no continuity between the tab(pin 2) of MOSFET and GND of board before startup. Also make sure polarity of your power supply input is correct. Positive goes to pin next to JST power switch jack.
This is a spin-off from the PCA (Pocket Class A) amp. It’s the same topology but I wanted a separate thread to discuss the technical aspects which are different. This amp is a joint effort between myself, BabyDontHertzMe (BDHM), and JPS64 whom both did a fantastic layout for the PCB. The DCA is designed for through hole components with lots of room for capacitor rolling options, a built in capacitance multiplier and CRCRC power supply section. There are 3 ground planes (PSU,Left, Right) that come together at a star topology. The board has almost identical high current traces on both sides that are joined with thousands of vias for a true low impedance path. Nominal design is for 20v Vcc, 125mA bias current and can be pushed as high as 25v Vcc for driving low impedance cans. Typical performance is 0.015%THD all H2 and a little H3 for 1vpp into 42ohm load. Can drive 42ohms as high as 544mW without clipping. Sound is powerful, and being zero global feedback, has an impressively wide and accurate soundstage. The signature is engaging and natural with no hint of fatigue. Tested with DT880-250, OB-1’s, and HE-400i. All sound fantastic and can get louder than you can handle comfortably without strain. In summary, it’s an easy to build amp and and designed for the DIYer who likes to tweak. The nice low noise PSU built in simplifies the power supply logistics.
Schematic of Production Board:
Actual PCB:
Stuffing Guide:
Please note that polarity of 4 jacks on front from left to right is +ve -ve / -ve +ve / +ve -ve / -ve +ve
Due to mirror symmetry.
Built up Amp:
Rear View
Measurements:
20.2v Vcc and 125mA bias
21.3v Vcc and 0.0066% THD
Power Measurement Test into 42ohm load:
Corresponding O-scope shot:
I was able to get 10.5vpp without clipping for 544mW into 42ohms.
BOM:
https://www.diyaudio.com/community/...class-a-dca-headphone-amp.322638/post-7509042
Actual PCB:
Stuffing Guide:
Built up Amp:
Rear View
Measurements:
BOM:
Part | Value | Device | Package | Description | |
C101 | 10 µ0 | CPOL-EUE3.5-8 | E3,5-8 | POLARIZED | Electrolytic 3.5mm pitch x 8mm dia |
C101A | C22/10 | C22.5B10 | CAPACITOR | Film 22.5mm pitch x 10mm width | |
C101B | C27/17 | C27.5B17 | CAPACITOR | Film 27.5mm pitch x 17mm wide | |
C101C | 0 µ1 | MKC1860-0U1 | MKC1860-0U1 | Wima part number | |
C101D | 10 µ0 | MCAP250V10U | MCAP250V10U | Fidelity | Mundorf Mcap part number |
C102 | 10 µ0 | CPOL-EUE3.5-8 | E3,5-8 | POLARIZED | Electrolytic 3.5mm pitch x 8mm dia |
C102A | C22/10 | C22.5B10 | CAPACITOR | Film 22.5mm pitch x 10mm wide | |
C102B | C27/17 | C27.5B17 | CAPACITOR | Film 27.5mm pitch x 17mm wide | |
C102C | 0 µ1 | MKC1860-0U1 | MKC1860-0U1 | Wima part number | |
C102D | 10 µ0 | MCAP250V10U | MCAP250V10U | Fidelity | Mundorf Mcap part number |
C111 | 1 µ0 | C5/5 | C5B5 | CAPACITOR | Film 5mm pitch x 5mm wide |
C111A | C10/6 | C10B6 | CAPACITOR | Film 10mm pitch x 6mm wide | |
C111B | C15/8 | C15B8 | CAPACITOR | Film 15mm pitch x 8mm wide | |
C112 | 1 µ0 | C5/5 | C5B5 | CAPACITOR | Film 5mm pitch x 5mm wide |
C112A | C10/6 | C10B6 | CAPACITOR | Film 10mm pitch x 6mm wide | |
C112B | C15/8 | C15B8 | CAPACITOR | Film 15mm pitch x 8mm wide | |
C113 | 2200uF | CPOL-EUE7.5-18 | E7,5-18 | POLARIZED | Electrolytic 7.5mm pitch x 18mm dia |
C113A | CPOL-EUE5-10.5 | E5-10,5 | POLARIZED | CAPACITOR, | Electrolytic 5mm pitch up to 18mm dia |
C114 | 2200uF | CPOL-EUE7.5-18 | E7,5-18 | POLARIZED | Electrolytic 7.5mm pitch x 18mm dia |
C114A | CPOL-EUE5-10.5 | E5-10,5 | POLARIZED | CAPACITOR, | Electrolytic 5mm pitch up to 18mm dia |
C131 | 220 µ | CPOL-EUE5-13 | E5-13 | POLARIZED | Electrolytic 5mm pitch up to 13mm dia |
C133 | 1 µ0 | C5/5 | C5B5 | CAPACITOR | Fil 5mm pitch x 5mm width |
C134 | 2200 µ | CPOL-EUE5-13 | E5-13 | POLARIZED | Electrolytic 5mm pitch up to 13mm dia |
C135 | 2200 µ | CPOL-EUE5-13 | E5-13 | POLARIZED | Electrolytic 5mm pitch up to 13mm dia |
C141 | 2200 µ | CPOL-EUE5-13 | E5-13 | POLARIZED | Electrolytic 5mm pitch up to 13mm dia |
C142 | 2200 µ | CPOL-EUE5-13 | E5-13 | POLARIZED | Electrolytic 5mm pitch up to 13mm dia |
C143 | 1 µ0 | C5/5 | C5B5 | CAPACITOR | Film 5mm pitch x 5mm wide |
C144 | 1 µ0 | C5/5 | C5B5 | CAPACITOR | Film 5mm pitch x 5mm wide |
R101 | RK09L12B | RK09L12B | |||
R102 | 100k | CMF-55 | CMF-55 | Dale 1/2W metal thin film 1% | |
R103 | 100k | CMF-55 | CMF-55 | Dale 1/2W metal thin film 1% | |
R104 | 22k0 | CMF-55 | CMF-55 | Dale 1/2W metal thin film 1% | |
R105 | 22k0 | CMF-55 | CMF-55 | Dale 1/2W metal thin film 1% | |
R106 | 1k1 | CMF-55 | CMF-55 | Dale 1/2W metal thin film 1% | |
R107 | 68R0 | CMF-55 | CMF-55 | Dale 1/2W metal thin film 1% | |
R108 | 250R | CMF-55 | CMF-55 | Dale 1/2W metal thin film 1% | |
R109 | 1k1 | CMF-55 | CMF-55 | Dale 1/2W metal thin film 1% | |
R111 | 68R0 | CMF-55 | CMF-55 | Dale 1/2W metal thin film 1% | |
R112 | 250R | CMF-55 | CMF-55 | Dale 1/2W metal thin film 1% | |
R113 | 47R0 | CMF-55 | CMF-55 | Dale 1/2W metal thin film 1% | |
R114 | 47R0 | CMF-55 | CMF-55 | Dale 1/2W metal thin film 1% | |
R115 | 270R | CMF60 | CMF60 | Dale 1W metal thin film 1% | |
R116 | 270R | CMF60 | CMF60 | Dale 1W metal thin film 1% | |
R117 | 270R | CMF60 | CMF60 | Dale 1W metal thin film 1% | |
R118 | 270R | CMF60 | CMF60 | Dale 1W metal thin film 1% | |
R119 | 270R | CMF60 | CMF60 | Dale 1W metal thin film 1% | |
R121 | 270R | CMF60 | CMF60 | Dale 1W metal thin film 1% | |
R122 | 270R | CMF60 | CMF60 | Dale 1W metal thin film 1% | |
R123 | 270R | CMF60 | CMF60 | Dale 1W metal thin film 1% | |
R124 | 270R | CMF-55 | CMF-55 | Dale 1/2W metal thin film 1% | |
R125 | 270R | CMF-55 | CMF-55 | Dale 1/2W metal thin film 1% | |
R131 | 10k0 | R-EU_0207/10 | 0207/10 | RESISTOR, | 2mm dia x 7mm long body, 10mm pitch axial |
R132 | 220R | R-EU_0207/10 | 0207/10 | RESISTOR, | 2mm dia x 7mm long body, 10mm pitch axial |
R133 | 1R5 | R-EU_0207/10 | 0207/10 | RESISTOR, | 2mm dia x 7mm long body, 10mm pitch axial |
R134 | 0R47 | R-EU_0309/12 | 0309/12 | RESISTOR, | 3mm dia x 9mm long body, 12mm pitch axial |
R135 | 0R47 | R-EU_0309/12 | 0309/12 | RESISTOR, | 3mm dia x 9mm long body, 12mm pitch axial |
V101 | BF862 | SST201 | SOT23 | TEMIC | SOT23 SMT package |
V102 | BF862 | SST201 | SOT23 | TEMIC | SOT23 SMT package |
V103 | JFET | 2SK170 | TO92-DGS | Field | TO92 package |
V104 | JFET | 2SK170 | TO92-DGS | Field | TO92 package |
V111 | IRF610 | IRF512 | TO220BV | N-CHANNEL | TO220 package |
V112 | IRF610 | IRF512 | TO220BV | N-CHANNEL | TO220 package |
V131 | 1N4004 | 1N4004 | DO41-10 | DIODE | DO41 package axial 1A diode |
V132 | IRF610 | IRF512 | TO220BV | N-CHANNEL | TO220 package |
X101 | 22-27-2021-02 | 22-27-2021-02 | 6410-02 | CONNECTOR | Molex KK 2-pin 2.5mm pitch connector |
X102 | 22-27-2021-02 | 22-27-2021-02 | 6410-02 | CONNECTOR | Molex KK 2-pin 2.5mm pitch connector |
X111 | 22-27-2021-02 | 22-27-2021-02 | 6410-02 | CONNECTOR | Molex KK 2-pin 2.5mm pitch connector |
X112 | 22-27-2021-02 | 22-27-2021-02 | 6410-02 | CONNECTOR | Molex KK 2-pin 2.5mm pitch connector |
X131 | 22-27-2021-02 | 22-27-2021-02 | 6410-02 | CONNECTOR | Molex KK 2-pin 2.5mm pitch connector |
X132 | AK500/2 | AK500/2 | CONNECTOR | unknown | 2-pin 10mm pitch screw terminal |
X1011 | SK104 | SK104 | SK104 | HEATSINK | Fischer Heatsink SK104 |
X1012 | SK104 | SK104 | SK104 | HEATSINK | Fischer Heatsink SK104 |
X1031 | SK104 | SK104 | SK104 | HEATSINK | Fischer Heatsink SK104 |
Hi Pcgab,
Actually, anything above 4.7uF is enough for practical bass extension needed. The larger caps have a bit more EMI pickup but only noticed when my fingers touch the body. 12uF is fine as long as room on board permits. I have 6.8uF purple Clarity Cap on my Aksa Lender HPA and find that sounds great. That’s a good price too.
Truth be told, the $0.35 10uF 35v Silmic II sounds darn good.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
X
X
Hi Pcgab,
X
Maybe I'll try an 8.2 instead, the 12's are likely a bit big for the board.
Thanks for the tips, X!
This might be useful for those who don’t have JST crimp tool:
JST XH 2.5mm 2-Pin Connector with LOCK Plug Wire Lengh 300mm x 10 Sets 726811952092 | eBay
10 sets is enough for 2 DCA’s
Thanks, Idiosyncrasy. The “Swiss Cheese” traces and vias are a JPS64 signature layout technqieue. The extra vias connect two planes of essentially identical traces on both sides to increase metal and surface area for low impedance electrical paths. Side benefits are enhanced cooling and strength of the traces and pads from being pulled off due to rework. Board is 2mm thick and copper is double thick 2oz with ENIG finish. Board is very sturdy and substantially built. Fab houses do not charge any extra for extra vias.
Haha, that’s like all the premium options checked.Board is 2mm thick and copper is double thick 2oz with ENIG finish. Board is very sturdy and substantially built.
Yes, plus the cool blue color vs usual green. Note that parts are all easily sourced and low cost (BF862 JFET and IRF610PBF MOSFET). No matching needed (unless you really are picky about balanced left right then match the JFETs to within 5% Idss). Easy to do with low cost SMT JFETs. The performance to price ratio is extraordinary.
The Aksa Lender HPA has lower THD but similar sonic profile of SE Class A. The Aksa Lender also has more gain, if that’s what you like. But I would say that a no global feedback SE Class A like the DCA, will have better soundstage and imaging. The DCA can be driven to very high bias (tested to 150mA which means it can drive 300mA peak current) as it has provision for larger heatsink. So can drive lower impedance cans with more power. I think you will find that both sound similar in that they are very dynamic and natural sounding with smooth response and low low noise. They are cheap enough to enjoy many times. Don’t need to settle on one. DCG3 is a great amp but I have not listened to it side by side so can’t compare.
Here is the BOM:
xrk971 Desktop Class A HPA v2 May 9, 2018
BOM
Part Value Device Package Description
C101 10µ0 CPOL-EUE3.5-8 E3,5-8 POLARIZED CAPACITOR, European symbol
C101A C22/10 C22.5B10 CAPACITOR
C101B C27/17 C27.5B17 CAPACITOR
C101C 0µ1 MKC1860-0U1 MKC1860-0U1
C101D 10µ0 MCAP250V10U MCAP250V10U Fidelity Component MCap
C102 10µ0 CPOL-EUE3.5-8 E3,5-8 POLARIZED CAPACITOR, European symbol
C102A C22/10 C22.5B10 CAPACITOR
C102B C27/17 C27.5B17 CAPACITOR
C102C 0µ1 MKC1860-0U1 MKC1860-0U1
C102D 10µ0 MCAP250V10U MCAP250V10U Fidelity Component MCap
C111 1µ0 C5/5 C5B5 CAPACITOR
C111A C10/6 C10B6 CAPACITOR
C111B C15/8 C15B8 CAPACITOR
C112 1µ0 C5/5 C5B5 CAPACITOR
C112A C10/6 C10B6 CAPACITOR
C112B C15/8 C15B8 CAPACITOR
C113 2200uF CPOL-EUE7.5-18 E7,5-18 POLARIZED CAPACITOR, European symbol
C113A CPOL-EUE5-10.5 E5-10,5 POLARIZED CAPACITOR, European symbol
C114 2200uF CPOL-EUE7.5-18 E7,5-18 POLARIZED CAPACITOR, European symbol
C114A CPOL-EUE5-10.5 E5-10,5 POLARIZED CAPACITOR, European symbol
C131 220µ CPOL-EUE5-13 E5-13 POLARIZED CAPACITOR, European symbol
C133 1µ0 C5/5 C5B5 CAPACITOR
C134 2200µ CPOL-EUE5-13 E5-13 POLARIZED CAPACITOR, European symbol
C135 2200µ CPOL-EUE5-13 E5-13 POLARIZED CAPACITOR, European symbol
C141 2200µ CPOL-EUE5-13 E5-13 POLARIZED CAPACITOR, European symbol
C142 2200µ CPOL-EUE5-13 E5-13 POLARIZED CAPACITOR, European symbol
C143 1µ0 C5/5 C5B5 CAPACITOR
C144 1µ0 C5/5 C5B5 CAPACITOR
R101 RK09L12B RK09L12B
R102 100k CMF-55 CMF-55
R103 100k CMF-55 CMF-55
R104 22k0 CMF-55 CMF-55
R105 22k0 CMF-55 CMF-55
R106 1k1 CMF-55 CMF-55
R107 68R0 CMF-55 CMF-55
R108 250R CMF-55 CMF-55
R109 1k1 CMF-55 CMF-55
R111 68R0 CMF-55 CMF-55
R112 250R CMF-55 CMF-55
R113 47R0 CMF-55 CMF-55
R114 47R0 CMF-55 CMF-55
R115 270R CMF60 CMF60 (for R115 to R123 recommended to use 1w parts here and elevate above board 5mm or more for cooling)
R116 270R CMF60 CMF60
R117 270R CMF60 CMF60
R118 270R CMF60 CMF60
R119 270R CMF60 CMF60
R121 270R CMF60 CMF60
R122 270R CMF60 CMF60
R123 270R CMF60 CMF60
R124 270R CMF-55 CMF-55 (can be up to 1k if using 600ohm cans)
R125 270R CMF-55 CMF-55 (can be up to 1k if using 600ohm cans)
R131 10k0 R-EU_0207/10 0207/10 RESISTOR, European symbol
R132 220R R-EU_0207/10 0207/10 RESISTOR, European symbol
R133 1R5 R-EU_0207/10 0207/10 RESISTOR, European symbol
R134 0R47 R-EU_0309/12 0309/12 RESISTOR, European symbol
R135 0R47 R-EU_0309/12 0309/12 RESISTOR, European symbol
V101 BF862 SST201 SOT23 TEMIC / Siliconix N-Channel JFET
V102 BF862 SST201 SOT23 TEMIC / Siliconix N-Channel JFET
V103 JFET 2SK170 TO92-DGS Field Effect Transistor Silicon N Channel Junction Type 2SK170 Audio Grade (optional instead of BF862)
V104 JFET 2SK170 TO92-DGS Field Effect Transistor Silicon N Channel Junction Type 2SK170 Audio Grade (optional instead of BF862)
V111 IRF610 IRF512 TO220BV N-CHANNEL MOS FET
V112 IRF610 IRF512 TO220BV N-CHANNEL MOS FET
V131 1N4004 1N4004 DO41-10 DIODE
V132 IRF610 IRF512 TO220BV N-CHANNEL MOS FET
X101 22-27-2021-02 22-27-2021-02 6410-02 CONNECTOR unknown unknown
X102 22-27-2021-02 22-27-2021-02 6410-02 CONNECTOR unknown unknown
X111 22-27-2021-02 22-27-2021-02 6410-02 CONNECTOR unknown unknown
X112 22-27-2021-02 22-27-2021-02 6410-02 CONNECTOR unknown unknown
X131 22-27-2021-02 22-27-2021-02 6410-02 CONNECTOR unknown unknown
X132 AK500/2 AK500/2 CONNECTOR unknown unknown
X1011 SK104 SK104 SK104 HEATSINK manufacturer Fischer/distributor Buerklin
X1012 SK104 SK104 SK104 HEATSINK manufacturer Fischer/distributor Buerklin
X1031 SK104 SK104 SK104 HEATSINK manufacturer Fischer/distributor Buerklin
These look like nice heatsinks and will handle the thermal load just fine.
WAKEFIELD 627-15ABP Vertical Heatsink TO-220 34.9 x 12.7 x 38.1(mm) *NEW* Qty.10 | eBay
I currently use these:
To-220 Heat Sink 1 Hole 10 Pcs | eBay
These Class 2 transformers have been found to be very low noise when used drive a DC step up.
GCi technoLogies AM-12800 12VDC 800mA Charger / Power Supply Amazon.com : GCi technoLogies AM-12800 12VDC 800mA Charger / Power Supply : Everything Else
Use something like this for the DC-DC step up or down.
That plus the built in cap Mx and CRCRC are all you need to have a PSU that’s as clean as a battery.
Very interesting. I was under the impression that log pots were the goto pots for audio. Why do you prefer linear?I use a linear 10k myself, not a fan of log pots.
Most affordable logarithmic pots are actually a combination of two linear tracks that give a log approximation.
I've used the loading resistor method mentioned by Rod Elliott here ESP - A Better Volume Control with excellent results. High quality linear pots are easier to get and cost less
. X is right about them tracking better, too.
- Group Buys
- xrk971 Desktop Class A (DCA) Headphone Amp
