I get it, David ... very nice on PC speakers when everything has nicely warmed up - an excellent test track for system performance in general, I would say, on a first rough listen ...
Don't give up, 🙂 ... and thanks for making it, and uploading ...
Try to listen for the builders hammering away on a roof, just after the rain, ~100yards in front. (and a bit left and downhill) It is a real thrill for me to hear low frequency sounds localized in front, through glass, in a gale! Poor buggers!
Sure but I doubt you'll get stuck when you RTFM. This device really requires it.
I've read better manuals though....
Ah hah! Yes, I heard 'extraneous' sounds at one point in the recording, that didn't tie in with rain 'sounds' - I didn't try and pinpoint what it was, just noted its presence - thanks for identifying the source!Try to listen for the builders hammering away on a roof, just after the rain, ~100yards in front. (and a bit left and downhill) It is a real thrill for me to hear low frequency sounds localized in front, through glass, in a gale! Poor buggers!
Edit: I was running this at high volume, to create an appropriately 'immersive' experience, and at one stage went outside to do something - I was struck by how strongly the sound carried through the window glass and beyond to the street - anyone walking along would have been completely bamboozled by this illogical phenomenon ... !
Yes it does and exactly what needs to be done. If we want to compensate for the additional effects of headphone playback then we need to measure them, build a filter and convolve it with the playback signal.
It is not as simple as you make out. If you want to reproduce the sound of your speakers and you measure the speaker/room IR, and the heaphone IR using the same mic position, then, in effect, you are doing a ratiometric measurement, where the mic response drops out. Measuring your heaphones with a small blocked meatus mic and, in effect, using the IR of my dummy head is not doing quite the same thing. This approach of the Realizer also ignores the possibility of sound transmission by another path ie. 'bone conduction', that is not the same for speaker and headphone, and is not picked up by the mic in any case.
There must be a bit of audiophile in me to obsess about such things, but please do not tell anybody!
I suppose they would be expecting fire, not rain...
James Taylor - Fire and Rain, Live 1970 - YouTube ...
Unfortunately, our house is in the thick of the bad stuff you've been hearing about, we have friends not too far away that had the flames aiming directly towards them ... luckily, conditions calmed down in time ...
Who knew they had youtube back then!
I could have dropped a bad taste b******* there.. Glad it turned out the way you say.
This really is a good-un, if I say so myself. https://www.dropbox.com/s/gs67gis7br3f5fm/blustery showers.mp3 Binaural. Not for the faint hearted!
Use permanent link below instead, as this file will be deleted shortly:
Freesound.org - "blustery showers.mp3" by dwareing
Requires creation of account to download the same hi-res mp3.
And you can use this for pre-recorded binaural recording? And my file still sounds like stereo? Perhaps you can afford to get some HD 219 for those camping trips..
ps. I just spent a grand total of £11.52 on some Koss KCS75, and I hear even more detail! Plus, with the aid of some Peltor ear muffs, I can have open or closed headphones. 🙂
- Hearing and the future of loudspeaker design
