I have said it before, but it looks like it is worth repeating.
The CCS part of the regulator can be assembled and tested at low voltage. Prove it alone is working. This will need one extra resistor to increase the grounding current at the selected Low Voltage for testing.
The the extra resistor can be removed and the CCS tested at full voltage using an appropriate load (power) resistor.
Then add on the assembly of the voltage regulator. Test the whole regulator.
Yes, thanks AndrewT, I forgot, I know that by own experience
- Power Supplies
- Simplistic MosFET HV Shunt Regs
