Hi Sheldon,
The 4596 is essentially the single diaphragm version of the 4599. I have measured and compared both and they are pretty much the same, wherein the 4599 is between 5.5-6dB louder. This makes sense being the 4599 has double the Sd as well as the impedance cut in half due to the parallel-wired voice coils.
The 4599 has a slightly smoother response, most likely because the opposing diaphragms cancel various mechanical vibrations. But, of course, it's also double the price.
All in all, both are great; the highest SPL drivers I have worked with. I hate to see them sitting on my shelf and hope someone can make use of them.
As far as waveguides/horns, I think it's more of personal preference. Choosing the right horn depends on the system as a whole and as well what the acoustic expectations are.
I think that if you use any of the many horn calculators on the internet to derive the length and mouth area you should be good. Then just shop for what is the closest to your caluclations.
Or, you can always build your own horn
Ad
Ad
Hi,Hey, do you think this can be used for midrange without any horn ?
Unfortunately, these are compression drivers, so you will need a horn with a 2" throat. Parts Express would be a good starting point.
