I was wondering about our ear's ability to discern phase correctly.
My first problem was with the large variations in frequencies that our magic ears can hear. A large range in frequencies neccessitates a large range in wavelengths.
Here are some numbers:
Speed of sound in air = 343m/s
Freq range = ~20-20000hz
Wavelength range = ~16m - 1.6cm
This means that if you move your listening chair a mere .8 cm forward, you've completely changed the phase of the 20khz frequencies compared to the 20hz. I know this is being picky, but this makes me question our ability to hear phase differences at all. If such a small motions of our head can make large differences in the phase of the sound we are hearing, when does it start to matter? I've never noticed a difference between leaning forward or leaning backward while listening to music, a difference of about 20 cm. This 20 cm changes the phase of 850hz by 180 degrees, while changing 1700hz by 360 degrees. You'd imagine that such a change would be noticable.
Any absolute polaritists want to speak out?
-Dan
-Dan
OK I'll have a go on it
First of all the most important: whatever the frequence sound travels at the same speed. If you lean your head forward the hi and low have the the same phase diff as it will have when the sound reach the place where your head was supposed to be (uppright position) some millisec later.
do you understand ??
so the sound is the same in a relative way but you're older, shorter of breath and one soundwave closer to death
Keld
Keld
so the sound is the same in a relative way but you're older, shorter of breath and one soundwave closer to death /Too true
When I did my degree in psychology in the early 80s I was very interested in psychoaccoustics, and read many a paper on the subject. None, repeat, None, showed any proof that absolute phase is perceived by the human ear, phase differences between the two ears are only used for the localisation of sound in space, and that mostly only in two dimensions, as the human ear is geared not to notice up and down, only left and right, and peceptual cues are used to differentiate height, ie bird song is up and scratching sounds are usually on the floor, showing you have a mice infestation!
Sorry Keld, but phis is correct, phase does change between positions, proportionately by the difference in frequency between the two wavelengths, this is one of the perceptual mechanisms the human brain uses to locate a sound source.
Now normally at this point I would duck and cover, but hopefully with the new regime in place, all I will get is constructive critique
Rod Elliot had a good series of articles about phase relationships and their audibilty. Basically, our ears care for harmonic content only, and not their components phasing, so we can only hear changes in phase when they create interference effects f.ex. (cancellations and such).
Having said that, i LIKE to have the minimum phase shift necesary on my audio circuits, even if all that is ruined by the internal crossover of my speakers. Such is life.
Come on you guys. Let's get back to the original question.
Or, Is this another post that goes off on a tangents?
The answer has nothing to do with phase, phase relationships, absolute phase, frequency, the speed of sound, psychoacoustics, wavelengths or localization.
Again, phish, I must say this is a most excellent question and I really hope it will get people to think.
When the hunter-gatherer came down from the trees he was always on the move. It was very important for him to know whether the thing he was hearing was moving or if he was moving and the thing was fixed in place.
You are moving, the speakers are fixed, the ear-brain knows how to deal with things when you move your head. Now if you clamped your head and had someone move the speakers...
dave
dave
You knew my answer I don't beleive in phase audibility, so *I* don't care. Yet, i like to keep my signals as "in-phase" as posible.
As for moving the speakers, its the same deal. Your brain will make it sound like the music is moving, but it will STILL be audible as music. It might change (doppler effect, frequency response change because of room, etc) but that'd be in no way related to the phasing of the harmonic content.
Hi phishead8
This is indeed a good question you asked.
The main fact is that our hearing system doesn't use phase to determine the direction of a sound source. It mainly uses the TIME DELAY between the ears to do so (I.e some other effects are also used but to a lesser extent).
Because of this, it doesen't matter that much from a first view, if you move your head back and forth while listening.
Our hearing system is performing a temporal correlation process on the lows and highs of the signals it receives. The more they correlate the more exact we can localize the source of an acoustic event.
According to John Watkinson our hearing system is able to distinguish inter earal time-differences of about 16 microseconds !
The signal localisation is performed on transients because with a steady state signal you don't have any unique time relationship between the left and the right ear anymore. If you'd use phase to detect direction by using only two receivers (in our case our ears) then the result would always be ambiguous.
Just try to to localise a sound source with sinusoidal character and steady level in a reverberant room and then try to localise somebody who is speaking in the same location. Guess which one you can do more easily ?
But there IS a relationship between phase and time as you have already noticed.
If your reproduction system has too much phase DISTORTION (i.e. the phase isnt't shifted proportional to frequency anymore) it will disturb the temporal alignment of lower- and higher frequency contents of transients (and music contains a lot of it -- at least I don't listen to steady sinusoidals but I don't know anybody else's taste so far).
To say it once again: detection of phase doesn't give you an exact direction of an acoustic event but phase distortion in a reproduction system would blurr the localization of sound sources.
This is one reason why some people prefer to listen to single broadband drivers: The absence of a crossover and the single source caracter introduce less phase distortion and give better imaging.
There was a good series of articles in Electronics World and Wireless World on that subject, written by John Watkinson. You can find some info in short form on this subject (amongst other stuff) written by him also under:
http://www.celticaudio.co.uk/technical2.htm
If I was unclear in any way don't be afraid to ask.
Anybody who disagress is also invited to shoot at me (In the end life would be boring if everybody always agrees to everybody).
Charles
Charles
I think it was the late Neville Williams in Electronics Australia magazine who was discussing the left to right phase difference of early (then new) CD players that because of cost, only had one D/A converter. Apparently it was rapidly switched back and forth between the two channels and as a result one channel always ran slightly behind the other. The remedy he sugested was to "collectively move your [heads] to the left about an eigth of an inch!" Sounds about right for 1/44,000 of a second phase difference.
Also, once while messing around with a dc/dc converter using ferrite potcores that ran at about 3.5 kHz and as a result made quite a piercing squeal, I noticed that if I moved my head slightly it made quite a difference to the perceived loudness of the sound. If I moved around the room there were very noticeable live and dead spots. The converter ran with a square wave and so the resulting sound from the ferrite core magnetostriction would have had lots of harmonics that would have added and subtracted as the listening position was changed.
GP.
GP.
Yea, interesting topic indeed. But Bill Fitz is correct, people are going off on tangents.
What Phish has brought up has nothing to do with interaural phase or time differences, so even though what Phase_accurate writes is interesting and mostly correct, it isn't relevant. If phish wrote about moving his head from side to side, or even rotating it, then interaural thingies would be significant but for axial translation, it ain't.
What is relevant is whether the human hearing system is sensitive to absolute phase and there is no significant evidence to suggest that it is. Even relative phase differences between signals are extremely difficult to perceive, particularly when there is a large frequency difference between the two signals. As for phase distortion, this is usually perceived in terms of "sound quality", rather than some tangible specific quantity although it is reasonable to say that it may well result in a smearing of the sound image (increased localisation blur, something entire books have been written about).
DocP
As a pedantic footnote, the nominal range of human hearing is 20 Hz to 20 kHz. In reality for a healthy adult very few individuals would be able to hear anything above about 16 kHz which isn't as bad as it sounds because there is virtually no musical content above that anyway.
DocP
Hi DocP
Maybe I was a bit unclear with my statements (English isn't my mothertongue).
What I wanted to say is that phase alone doesn't matter at all.
Even the different phase lag for different frequencies for a given distance and the subsequent different change in degrees for the same change of way doesn't matter, as long as the alignment in time fo rlow and high frequencies stays the same.
Moving back a little would have the same effect as pushing the start button on the CD player a little later and vice versa (I deliberately omitted room interactions for simplicity, but thats what Circlotron experienced during his converter adventure ).
Charles
Charles
sam9
If human hearing was really as sensitive as audiophiles believe (including me in moments of weakness and irrational aberition), I doubt we could make sense of a damn thing we hear. It's pretty clear that the brain performs extensive but very useful "signal processing" to both visual and audiatory inputs. If anyone tried to market devices that do anything comparable he'd be cursed for massively corrupting the sanctity of the signal path -- his very name would be reviled - in comparrison Bose would be among the saints.
Doubtless all this processing is not directed toward not to aesthetic ends but rather toward snagging the next meal and avoiding becomeing some other creatures meal.
Keld said:OK I'll have a go on it
Keld
Not quite. The wavelength of high frequency signals is much shorter, so you do not shift the phase of all by the same amount.
Move a couple cm and you have completely inverted the phase of a high freq signal while you have barely moved the phase of a low freq signal at all.
This sort of effect is why moving speakers a small amount has a major effect on the sound at any location in the room. When you add in the effect of multipath you quickly see how silly it is to tweak power cords for the microscopic (if any) effect you will get rather than moving your speakers an inch or two which, in most rooms, will have a big effect.
From what I have read (mostly just subjective tests of phase reversal, and we all know how valid subjective "tests" are), those who claim to hear a difference usually claim to hear it in things like bass drums which will typically have very long wavelengths. It may be that it sounds different, but who can say which is correct, and on which recordings? Yet another angels dancing on pin heads issue...
MR
Further tangents.
I repeat:
<blockquote>
The answer has NOTHING to do with phase, phase relationships, absolute phase, frequency, the speed of sound, psychoacoustics, wavelengths or localization.
</blockquote>
Anyone who has looked at music on a scope knows the answer - even if they don't know they know it.
Eventually, someone is going to nail this.
I repeat:
<blockquote>
</blockquote>
Thanks for the replies.
It is always nice to come back to a seemingly unanswered question to find 12 replies.
phase_accurate, I am not convinced that the phase has any effect on localization. (I am not talking about the phase difference between the speakers) When I had my ESLs up and running I would be able to have a very well defined sound stage. This sound stage did not disappear as my head was leaning forward or backward. It was even obvious if I was standing behind my chair. As long as I stayed in the beams of the ESLs I could localize the sound to a pinpoint.
The fact is that the phases of the different frequencies vary greatly from each of the listening positions that I mentioned, and I didn't notice a single difference.
My question, by the way, is neglecting acoustical effects from rooms, as they are as different as people's musical tastes.
-Dan
-Dan
phishead8 said:The fact is that the phases of the different frequencies vary greatly from each of the listening positions that I mentioned
<i>No, they don't!</i>
<i>You shouldn't</i>
<i>assumed</i>
-Dan
And of course you question remains unanswered.
Jteef,
Impulses are merely made up of infinitely many sinusoidal waves. They effectively happen at all frequencies. Simple Fourier analysis. So, I merely apply the same techniques as above. The frequencies all start from the speaker in phase, but by the time that they reach my ears some of those frequencies are in phase, some are completely out of phase, depending on the exact distance from speaker to ear. It still sounds like an impulse to me, however. Nice try.
-Dan
-Dan
- General Interest
- Everything Else
- Question about phase and chair placement
