Following on from some of the discussion on this forum about building chip amp power supplies, I am pleased to announce the addition of another page to the Gainclone section at Decibel Dungeon. I hope that it will answer many of the typical power supply questions that regularly crop up here.
I have tried to explain things both simply and comprehensively but most importantly, I have focussed on the safety aspects of building a mains fed power supply. I sincerely hope that all chip amp builders will make use of this resource and that it will keep them, and their property safe.
If you think that there is anything to add to the guide, or anything that isn't explained clearly enough, please use this thread to point that out, and I will make the necessary amendments.
A big thank you to AndrewT who took time off from his dancing) to proof-read the guide, and suggest corrections and additions.
You can find the guide here . 😉
WOW! great tut nuuk, it really helped me with discrete diodes and bridge rectifiers. best of it is its rite in time for me to build my PSU for my bridged gainclone. One question i think i always get mixed with, a transformer wired with twin secondary's has a positive and negative rail, when its wired as a center tapped trafo does it still have a positive and negative rail along with a ground or is a say +25 0v(ground) +25. i only ask as buiding my bridged lm3886 i need to fit the terminals and noticed the LM3886 has +v +v -v and ground pins. my first thought was, +v -v and ground were what i used to connect to the psu but now im questioning my self. admitidly i should post this in the chip amp section but the problem has just arised and reading this tut i feel more \might ask similerl so it seems like the rite place.
Once again great tut!
No transformer has positive or negative outputs. It is all AC until after the bridge rectifier(s).
If you have a centre-tapped traffo, you can (only) feed one bridge and you get a single positive and a single negative rail out of that. By referencing those rails to the centre tap you get your +/- voltages.
If your transformer has twin secondary windings, you can use two bridges, have two sets of positive/minus rails, and the zero volt rail is the junction between the negative or one, and the positive of the other (as in the diagram below)
Just in time for me too as I'm starting my PSU today or tomorrow.
The only thing that didn't make sense is use of the lightbulb protection... specifically, wouldn't you test with the 40W, then the 60W, then the 100W, THEN use the bulb bypass switch?
BTW: Rod Elliott has 2 t's
Better change that then Greg. I don't want to upset Rod! 😉
The only thing that didn't make sense is use of the light bulb protection... specifically, wouldn't you test with the 40W, then the 60W, then the 100W, THEN use the bulb bypass switch?
I'll let Andrew answer that one Redshift, and then update the guide if necessary. 🙂
one more thing about cap orientation on these + and minus rails of the psu, on the plus side obviously the positive pin of the cap is on th e positive rail and negative on the ground, on the negative rail is this the same case or does the negative leg go on the -v rail and positive leg on the ground like this?
or am i just being silly!
Think of the voltage rails being rungs of a ladder.
The positive rail is the highest, the zero volt rail is in the middle, and the negative voltage is the lowest rung.
And the rule is, the positive side of the cap always goes to the higher rung of the ladder.
Another way to think of it is 0 is higher than any minus figure.
So yes, your diagram is correct (and it wasn't a silly question). 😉
Great analogy, itj ust seemed a little daft when i went over it in my head but the way you put it across was spot on!!!
Nice job on the article but I would have to disagree with the following sentence in it, or possibly only the way it is worded:
Generally the most capacitance should come immediately after the bridge rectifier with the 10-100uF on each power pin of the chip amp. Whether or not this has as much *magic* depends a lot on the source and speakers. When either of those color the sound it can mean doing odder things to the amp but I would rather have a tonnally & detail accurate amp and replace the parts with a problem instead.
I suggest the following arrangement. About 10-100 uF after the bridge rectifier, and 1000 uF on each pin of the chip amp
How do you mesure to ensure the rectifier is ok, do you mesure from each dc out point to the ground of the transformer?
kanifee said:How do you mesure to ensure the rectifier is ok, do you mesure from each dc out point to the ground of the transformer?
A bridge rectifier is just 4 standard (for this purpose) diodes, you can use the diode test on any multimeter.
! said:Nice job on the article but I would have to disagree with the following sentence in it, or possibly only the way it is worded:
The guide is meant to be a 'how-to' rather than a 'recipe' for want of a better word. My advice (to beginners) is always to go with the most basic of GC's to begin with. And the 'accepted' circuits did use a small amount of capacitance after the bridge, and 1000 uF on each voltage supply pin of the chip. I agree a lot depend son what loudspeakers the GC in question will be used with.
So that's not 'set in stone', and everybody is welcome to try their own 'recipe' for the best sound in their system. But adding yet more variations to a beginner's guide can just make the whole process seem even more daunting! 😉
Thanks for the positive comments guys. If the guide helps just one person get started with a GC, and they get the same thrill that I got on hearing my first GC, it will have been worth the effort. 🙂
Kanifee, I presume that you are asking about checking that you have the correct voltages rather than checking the bridge rectifier is OK (although one depends on the other).
So yes, you measure voltages between two points where you have different voltages. Where you measure the output of the bridge rectifier depends on if you have one or two or them coming off the same transformer.
If you have a centre tapped transformer with a single bridge, you would measure from the + leg of the bridge to the centre-tap of the transformer to get your positive rail voltage, and from the - leg of the bridge to the centre-tap, for the negative voltage.
With twin bridges, you just measure from the + leg to the - leg on each bridge. Then at the point where you join the bridges together (where ever you do that) you can check the voltages from the + leg, and the - leg, the point where the join is made.
quick q then, i have a transformer of 15-0-15, what should be my voltage from the rectifier bridge?
kanifee said:quick q then, i have a transformer of 15-0-15, what should be my voltage from the rectifier bridge?
Looking at the table in the guide (hint 😉) it will be around 21 volts.
Nuuk said:
Looking at the table in the guide (hint 😉) it will be around 21 volts.![]()
The table could include the bridge rectifier loss.
(VAC * 1.41) - (2 * Diode Forward Drop) = DC Output @ rated transformer load.
Of course the remaining question is whether silicon or schottky diodes are used since the former has about half the drop of the latter though it's typically under 1V difference either way, and that (most?) people would probably be measuring their supply voltage while it is lightly loaded or not loaded at all (to confirm proper operation before powering the amp with it) instead of at the transformer rated load so the voltage will be a little higher.
Again, I don't want to go into so much detail it looks like a University degree course. However, it is important to stress that a load must be connected to the bridge when taking the measurements. Hence the following quote from the section on testing! 😉
You will need to have your reservoir capacitor connected on the output of the bridge rectifier to provide a load. If you don't you will not measure the correct voltage!
- Chip Amps
- Chip amp power supply- a beginners guide
