Anyone have Datasheet of the PCM64??
Moderator
Joined 2003
hatasa said:
Really no one have info of this there?
It is the 18bit parallel DAC...
There is the PCM63 which is part of that family but I couldn't find any info on the 64.
You can buy it at a few places, it has been used somewhere by Sony, there part number is 875997028.
Calling or mailing TI or Sony might bring a solution.
/Hugo :)
No datasheet, this is all i have:
18 bit, one channel.
parallel input, ttl, CSB/COB input type
THD+N -96dB
current ouput, unipolar -2.0mA, bipolar 1.0mA
powersupply +5 and -15V 415mW
42pin .6" DIP, plastic
gain error 0.5% max, drift 10 ppm/.C max
Vos drift unipolar 2.0 ppm/.C max, bipolar 2 ppm/.C max
Vos error bipolar 0.3%FSR
temp range 0-70.C
Hope this helps anyway,
GuidoB
Hi, Hatasa
As far as I can remember, the PCM64 was a low cost version of BB’s huge expensive industrial 18 bitter DAC729. No this one is not on TI’s web site either. It was one with trimpots for the last 2 LSB’s to trim it to 18 bits accuracy.
To find the PCM64P I think you have to dig through BB’s paper databooks from 8-10 years ago or so.
Cheers
