ANybody able to give a sonic ranking for UCD180 compared to other amps AKSA 55 for instance?
John
John
Check the thread "UCD180 questions". Some folks have posted
reviews, however not specifically AKSA versus UCD180.
Michael
Michael
Thanks Michael,
Yes I already checked that thread but I have not heard the amps mentioned there. I have built AKSA & Gainclone amps and wondered about UCD180 being a step up from AKSA?
John
John
I don't know if AKSA and UCD180 are quite comparable concepts. AKSA is a solid state Class AB amp (correct me if I'm wrong)whereas UCD180 is a PWM Class-D amp. However, sonically I believe a well-built UCD180 amp may outperform an AKSA.
I am also planning to build an UCD amp but it's hard to tell which
concept is really better. We need more reviewers.
Michael
Michael
mlihl said:I don't know if AKSA and UCD180 are quite comparable concepts. AKSA is a solid state Class AB amp (correct me if I'm wrong)whereas UCD180 is a PWM Class-D amp. However, sonically I believe a well-built UCD180 amp may outperform an AKSA.
Michael
It would also be interesting to hear people's reactions to these different technologies in the various bands of a triamped system. I suspect, for no good reason whatsoever, that preferences might go class-D for bass & mids up to 2.5 kHz, and class-AB or class-A for the highs. This is completely speculative, of course.
Francois.
Francois.
Hi Francois,
Class D (UcD) performs extremely well for the high frequencies as well, clearly better than my Accuphase that should be straight to well over a few hundred kHz. With the UcD things are just clearer, not in the sense of more high, but in the sense that the music sounds purer, less things added, less curtain in between the musicians and you. This less curtain effect is stronger than most people expect, at least I was very surprised to hear my far more expense Accuphase being blown away by the UcD.
I`m actually now using the the UcD180 for tweeter and midwoofers (1 for tweeter and 1 for midwoofer and active crossover, actually DSP) and a Tripath based Marantz for the woofers (will be replaced by UcD400 or 700). Works very well, I just finished this setup and first listening tests are very impressive. Very good imaging, you don`t hear or locate the speakers, just music.
Best regards
Gertjan
ghemink said:
Hi Francois,
Class D (UcD) performs extremely well for the high frequencies as well, [....] at least I was very surprised to hear my far more expense Accuphase being blown away by the UcD.
Best regards
Gertjan
Thanks a bunch - I already decided on a pair of UcD180s for each woofer (twin 4 ohm voice coils), but it's nice to know I can also use them for mids & higher. The current limit won't be a problem even with 50 volt supplies since box tuning will be set to 22 Hz, putting the higher impedance peak right in the middle of the woofer passband.
Mids will be another issue. Fortunately I found a Peavey CS-800 chassis missing only the power amps, so that's a possible home for some UcD400 modules. Have to do something about the fan and the gaudy faceplate, though....
Francois.
Some swedish guys seem to be preparing for a comparison of PWM modules: http://www.diyforum.net/phpBB2/viewtopic.php?t=1725
Will be interesting what they find out...
Thanks for the replies - I'm interested in the UCD modules absolute sonic ranking not necessarly among Class D amps only.
I contend that a new technology in audio should push the sonic envelope (so to speak) and should not be compared soley based on what technology class it falls into.
John
John
Shame I cant read Swedish 🙂 but what are the three modules? I recognise the UCD180's and I can see one has a Tripath chip but I dont know what it is and whats the one enclosed in Aluminium?
No LC audio module either.
One is ICE, one is some Tripath and finally UCD module
Maybe someone will do a translation to english when it is published?
John
John
wytco0 said:and whats the one enclosed in Aluminium?
B&O Ice Power
Note that the Tripath & B&O use the "Red Amindon type 2" inductors - also second sourced by others (Micrometals).
John
Edit:-
Ah - John you beat me to it - John 🙂
The tread from the Swedish DIYforum is about a blast among ClassD amps.
The blast is to be during november and will probably sort out a "winner".
I have listened to a friends UcD180 and compared it with some other amps.
It sent a Bob Carver Sunfire stereo amplifier to be ashamed in the corner. The UcD had so much more 3D and no distortion.
It formly crushed a Vincent sp331 amplifier. The Vincent was found having exagerated bass and treble and the bass produced was cloggy and indistinct. The vincent belonging to the same guy that owns UcD sold the vincent the day after the listening session.
Compaded to my own Musical Fidelity X-A1 the UcD was superior in every aspect, but the X-A1 did a far better job than the Vincent.
Another friend has evaluated the UcD against Sentec PA9 mono amps, and his conclusion was that the UcD did everyting the PA9 does with magic even better.
I´m ordering my pair of UcD400´s tomorrow and I´m aiming at having the amp completed before x-mas. 😀
The UcD is one of the best amplifiers i have ever heard. It works extremely well with Carlsson speakers.
opps.. long post for beeing the first...
Best Regards,
Pontus
Best Regards,
Pontus
I can't read swedish either, I trust the one with the big ugly IC is Tripath right? Looks like that's their input stage.
Many have made that direct comparison already. Seems the ZapPulse is still an excellent amp but the UCD generally comes out ahead for a few reasons.
mlihl
It would be interesting to know how the UCD does against
a Zappulse...
Be aware!
I have heard & tested several pwm/"digital" amps, and have found one thing common: in a short listening-session/blind-test, they all "bloom", but I have not been able to live with any of them for more than a week...
My N-channel always finds it's way back...
Arne K
Arne K
Re: Be aware!
Yehh well..
Some people prefer canned soup over homemade too
Cobra2 said:I have heard & tested several pwm/"digital" amps, and have found one thing common: in a short listening-session/blind-test, they all "bloom", but I have not been able to live with any of them for more than a week...
Arne K
Yehh well..
Hello,
I'm a newbie and have been following this thread with much interest.
I have some questions for the experts.
Is there something to be gained sonically using two transformers instead of one?
About caps ichoice: PS: Black Gates are very expensive, Cerafines are hard to find, what about Jensens 4-pole?
How better AD8620 really is instead of the standard OPamp?
And last: this is going to be my first DIY project, how difficult is it really?
Thank you very much
Thank you very much
- Class D
- UCD180 Vs Others
