yes.
mlloyd1
mlloyd1
Originally posted by lumanauw ... What is Q6-7, Q10-11, Q8-9? Are they current mirrors?
KLe said:
A question I have is ... can an Input Stage be made to produce sufficient Gain , Current/Voltage drive and a low output impedance to remove the need for a VAS?
ciao
Nelson Pass has several 1 and 2 stage amplifiers from Aleph through Zen. His Super-Symm topology can bridge two stage gain paths together to get higher power. The Pass DIY website has great info, as do the Pass product service manuals.
95dB OLG
As per low Zout, there is no need for that if you use an T output stage
forr said:Said otherwise, what happens internally when an input pair has more transconductance than the input pair of the other polarity ?
The complementary drive to the symetrical VAS will be a bit imbalanced and you’ll get a little more even harmonic distortion.
Glen
Because the (not so good) output stage being used demands more gain to fix it's distortion more than the folded cascode can provide?Why folded cascode is seldom used in audio amplifier?
Measurable distortion?
What about how it sound
Pavel, please take a look at post no.66 in this thread.PMA said:You can start playing with structures like this. The only question is if it makes any sense for audio.
It make sense, that topology sound very good and is unconditional stable. The output stage has CFP drivers plus three pears of ThermalTrack devices (NJL0302/0281)
lumanauw said:This one similiar to Mr. Cordell's principle, but the patent's aim is to get a stable current in the VAS (#5,783,970). The drop on R4 is feeded back to get apropriate CCS from T6-T7.
Yes, it is quite similar. Have you got a patent number for it?
Thanks,
Bob
roender said:Constant Vds, very good common mode rejection, no connection to possible dirty ground
Have you built working sample?
roender said:
95dB OLG
SymAsym rebuilt?
- Unipolar vs complementary input stage
