Topology Federmann, HQQF-55 ...
I circled the track that Pavel is speaking about.
BTW - this circuit has probably never worked yet, I can see that transistors have not been inserted and soldered yet - circled as well.
Pavel -
Of course no one here would understand because of the language barrier.
SY, I would appreciate if you could sweep the rubbish.
Pavel
I have read his site, google translate is sometimes ok. 🙂
I agree that its a lot of rubbish, but otoh this is an open forum, and I have seen a lot of other threads with more rubbish. 😀
SY you are in a hurry?
Cheers
It has nothing to do with realistic construction. See e.g. for output inductors, dimensions and supposed type...DC blocking - ceramic capacitors (suplly voltage?),conected together with thick, long line, Boucherot cell too.
Is not a supporter of THD measurement range, in my opinion is not sufficiently informative about the properties of amplifiers. I we will wait until everything is ready and will be measuring and listening tests.
I am also very curious to understand how your novel output stage works. It uses only N-channel MOSFETs in both push-pull halves :
Technical parameters of amplifiers 4Ω
End transistors 2 x 4 x IRFP240/9240
Technical parameters of amplifiers 2Ω
Technical parameters of amplifiers 8Ω
PMA🙂 Library, Library Eagle🙂
