Studio Reference Amplifier
Sir Mile, thank you again for you advice!
My problem was in crappy multimetr)
When i reverse polarity of probes VAC is gone😕
Then i connect it to my temporary chip amp(TDA9273 with t-form NFB) and it works well. Audible improvment is MUCH less 50Hz noise in speakers compared with unreg psu with two 22000uF.
Next step is 4 channels SR200:spin:
Construction in progress.
I'm trying to use the same shunt regulator for a citation 12, I'm planning use 2 of them for channel, have you improved with your project? do you think is possible?
thank you
vito
Hi all.
I'm trying to make psu of sr50
but It's my first time making amp
and there's something I need your help
1. i see two 2SC5200 in schematic
but there's only one in pcb
is this pcb wrong? or is this ok?
2. and.. what is that 2k2 resistor tie to MPSA42//MPSA92 ?
just simple resistor or something else?
i don't know what to buy..
3. my hometown use 220v AC,
what transformer i should buy?
is this ? ( 220v AC primary // 2x40v AC secondary )
4. right side of trans, 4 diode making diamond
and the number 35A/400V
what is this?
Hello all!
I finnaly finish 4 chanels of sr100.
It sound well, much better bass and more detailed highs compared with tda's.
On oscilogram present overshot, like I saw in Thimos build. Caps and resistor slightly improve it, but not completely.
Do I need zobel on output?
Here some ampporn:
