IF Zobel NET has HIGH temp, then there are HI-freq oscillations content superponed to audio content,
you must look OUT signals (before Zobel NET OUT) with oscilloscope,
look at 10KHz square wave OUT response, if are there Overshoot, Ringing, Settling time (or oscillations)
Post some response oscillograms here...
How do you change the bias voltage can be adjusted?That's how it worked. The setting is smooth and fine. I still ask, will 23mV on the emitter resistors be OK?
If everything is correct, by turning the trimmer P1, you can observe the 0R33/5W emitter resistors.How do you change the bias voltage can be adjusted?
- Studio Reference Amplifier
