File Format Conversions and Resampling
12/28/2008 Rev 1: soundcheck - input are taken from The Linux Audio To Go thread pretty Contributors: Paolo aka UnixMan
06/22/2009 Rev 2: soundcheck: sox 14.3.0 introduced. Improved parameters for resampling introduced.
Ths part of the Wiki is supposed to explain how to convert from this to that format and or resample in Linux.
As usual there are 100dreds of methods to do that, let start with some nice commandline tools to get this Wiki going.
I'll explain later on who to build a a very simple batch-converter script, which you'll love for converting
SOX
The most important and powerful tool for data manipulation is probably SOX, which is also available on MAC and MS.
You can also use SOX for realtime playback using its small "play" tool and even recording.
It is highly recommended to run SOX 14.3.0, though it needs to be installed from sources.
SOX - Samplerate Conversion
Have a look at
https://src.infinitewave.ca/ . (175db! noise rejection! compared to 145 with libsamplerate)
You'll see that SOX is the leading edge converter if run with -v -s -I -a
Some more information over here
https://sox.sourceforge.net/SoX/Resampling
v=very high quality 175db noise rejection
s=steep filter bandwith 99%
I=intermediate phase response
a=allow aliasing/above the pass-band
(from 44.1 to 96k)
sox <inputfile> <outputfile> rate -v -s -I -a 96000
WAV-2-FLAC
This will generate an <inputfile>.flac and delete the original
flac --best --verify --delete-input-file <inputfile>.wav
FLAC-2-WAV
This will generate an <inputfile>.wav and delete the original
flac -d --delete-input-file <inputfile>.flac
APE-2-WAV
mac <inputfile>.ape <outputfile>.wav -d
Using-shntool
https://etree.org/shnutils/shntool/ - Swiss Army knife for converting files
shnconv -o flac file.ape file.flac
How-to-handle-tagging
https://easytag.sourceforge.net/
