About the trebles on a Wharfedale Diamond 9.6
Hello !
I got, a few days ago, a pair of Wharfedale Diamonds 9.6, a 3,5 ways with 4 speakers : a dome tweeter, a dome medium, a medium-bass speaker, and a... boomer-woofer (?).
From what I could read online about the crossovers, there's first and old thread on diyaudio :
Modifying Diamond 9.6 crossovers.
It seems that the crossovers frequencies are :
150 Hz, 1 khz, and 6 khz.
On this thread, system7 draw the crossover schematic, here it is :
Derwhalfisch, who begun this thread, created a nice infographic for the crossover boards :
And now, the problem :
I find the trebles on these speakers... Difficult to find ! 😕
The tweeters are working, it is not the problem.
But it sounds like with a curtain covering the tweeters... The cymbals sounds as if there was felt glued on it, the triangle like recorded from the backstage. There is not this high treebles giving "brillance" to the percussions, or a hint of acidity to the violins... And the medium is powerfull. So, on a small jazz formation, or with electronic music, you can forget these defaults for a time. But on a symphonic orchestra, no high on the violins, and a medium making all the stringed instrument...Messy, not clear.
So my questions are :
- is there a owner of these speakers, or of on floor speakers of the same line, who could make the same constatation about the trebles of these Wharfedale ? Is this sound the original sound of these speakers ?
- If it's not, is it possible that the components of the crossover have suffered from an overload in their past, with all the speakers in working order ?
- And, if this is the normal tonality of these Diamonds, is it possible to improve a little the highest frequencies in changing slightly some values in the crossover, to give a little "shine", a little more relief to these trebles ? I find that this tonal balance, with emphasis on the mediums and weak trebles, is disapointing...
Thank you ! 🙂
Thank you ! 🙂
