Lowther cabinet plans
Here are my Medallion II cabinets, I'm using 8 ohm PM2A drivers. I use a subwoofer with them, almost finished an active crossover to use with them, should be done a a couple of weeks.
To add to that, it seems the most successful typical Lowther drivers is either a WAW, most often OB, or a BIG horn, but in the real world all the drivers won’t fit optimally in all those horns.
I have, just recently, moved the PM6A and M6c out of that since they actially work in a miniOnken so might work in a standard reflex as well.
dave
Might as well post my speakers. These are modestly sized OB's with PM6A's and a guitar speaker called a Tone Tubby serving as a woofer. It was designed by Jon Ver Halen when he was the US distributor for Lowther.
Which Tone Tubby? I have the original plans from Jan that show the passive series crossover, but, as far as I could tell, the referenced Tone Tubby is no longer available under the same model name.
The one below looks like the same driver, but as I mentioned in another thread the efficiency is higher than I recall. So I'm not sure if it actually is the same driver. One of the advantages of the original design was that both drivers were 96dB efficient, so there was no needed for padding one of the drivers down. Maybe @Jon Ver Halen knows?
https://www.tonetubby.com/all-products/alnico-red/
If this is still relevant, back when I bought a pair of MarkAudio A12P here in Hong Kong, the reseller had a pair of Lowther TP1 corner horns playing. Well, this classic design was probably guessed or approximately calculated without full modelling as mentioned, but there was nothing sad about it. It delivered wonderful, room filling and balanced sounding music. If you have space for them and the required handiness for construction, I definitely recommend them.
Reactions: flex2
The Lowther Academy plans look interesting. Any feedback from anyone on what they actually sound like..
I have unfortunately not heard them myself but FWIW read a review claiming that indeed the indirect speaker adds a spacious dimension to the sound. I have always thought that a variant optimised for a much more affordable pair of fostexes could be a cool project...
