Vishay z-foil resistors - major sticker shock
Joined 2003
so I just picked up a used wyred for sound preamp, and the mfg offers an upgrade of 24 Vishay z-foil resistors. so I say to myself, I'm a DIYer, I can do this myself.
but then.... digikey sells them, for something like $20 EACH. $20 for 1 resistor. this is digikey, not some boutique high end audio store.
I've never heard of anything so outrageous. (except prices for boutique cables)
Not sure what I am allowed to share. The low specified Tc comes from a substrate that has the same thermal expansion and contraction coefficient as the resistive body. But the masses of the substrate and the resistive body are not the same thermal contraction/expansion gets out of step with the resistive body at some freq range.
I've measured it for a project I consulted on. Can't give any details but it might be worthwhile to look into it.
Jan
  • Thank You
Reactions: indra1
I had no idea that these existed. I haven't cracked open the preamp yet, so I don't know how accessible they will be or even if they are through hole or smd.
here's what the mfg says about their stage 1 upgrade ($850)
Our available Stage 1 STP-SE upgrade features 24 Vishay Z-Foil resistors, four premium inductors, four Schottkey diodes. These enhancements which focus on the power supply and input/output buffer circuits present greater fidelity and definition.
their stage 2 ($1750)
The Stage 2 upgrade, includes all of the above plus our discrete proprietary regulators, an upgraded IEC inlet, 48 Vishay Z-Foil resistors located in the resistor ladder volume control, 16 upgraded high frequency filter capacitors, an Premium upgraded fuse, and a green OLED display. Direct attention to the signal path throughout the volume control and filtering circuit yields major enhancements to an already exceptional product.
I looked at their website regarding the upgrades, the pictures show through hole parts. If it was my preamp, I'd install the inductors, diodes and "high frequency filter capacitors" and pass on the z-foil.
I would not want to mess with the ladder volume control, it already is better than most of my preamps.
Then again, I'd just listen to it.
You bought a very nice preamp!
In audio they offer no advantage over a good low TC metal film resistor.
I agree.
They are made for use in test instruments for UHF TV and radio all the way up to satellite frequency.
I have seen there wire wound counterparts in very old RF test instruments. They have a special non inductive wind.
It is all do do with the shape of the resistant element being non inductive at hundreds of megahertz and gigahertz.
For audio it is down to wallet thinning therapy as they do not pay for themselves if used below 500Mhz.
Reactions: jan.didden
