Pearl 3 Burning Amp 2023
Wow, okay... it just sings beautifully 😍
Hey, either I may have a cure for my "wanna dual mono PS, but I love this custom pair of chassis!" problem, or maybe not....
See if modushop will custom make me another power supply chassis box! It would either need two power cords, or a connector between chassis, shouldn't be an issue.
Now sit back a minute and figure out if a good idea, or just a flash of early ( not that early) onset dementia.
To the modushop site!
Russellc
Just a short question... During many hours of listening I noticed a somewhat sharp or overemphasized upper mid/ treble range, and I think it was the reason why I changed the gain. However, I had to set the input capacitance to 320 pF (100+220) to tame this range to some extent. The cartridge is a Nagaoka MP-500; J2 of course shorted. Is it normal?
PS: I tried two different preamps (Iron Pumpkin, Rega), same result.
Jim, I tried it of course, but then the highs were sharp, elevated.
Now I replaced R22 with 68 ohms instead of 220 ohms for reduced gain (putting 100 ohms into the place of C16 is not necessary a good idea if one wants to change between MM and MC by simply removing the jumper - it gives only 95 ohms instead of 2.2k).
With this feedback the sound changes somewhat, sadly, I miss the gorgeus openness.
(I also made a trial with my old Lehmann Black Cube, okay, it sounds boring, but no elevated/sharp highs.)
Hmm... I've left the Pearl on for about 3-4 hours now without playing any music, and the sound is noticeably improving. Could it be that it just needs burn-in time (I think I read that somewhere)? I've listened to it for about 5 hours so far, so it's now racked up about 9 hours in total. Maybe I'll increase the gain a bit once the sound settles in so nicely...
Reactions: Russellc
