Depletion MosFET Buffer
Joined 2002
Here is a little buffer using depletion mode BSP129 SMT MOSFETs.
It will drive low impedance loads at .000% thd range. Frequency response is very extended to video range.
It needs some heatsinking or lots of copper because the current is close to 100 mA.
The circuit is the old White video buffer with silicon.
Reactions: skunark and Vix
Reactions: wayne
