SEAS 29TTFCD/G H1500-6ohm
A few years ago I purchased some drivers from PartsExpress, and one of the drivers were these Seas H1500 tweeters.
The PE part number was 299-760 and stated "Seas H1500 1" Aluminum", and the sticker on the side shows "29TTFCD/G H 1500-6ohm. Made In Norway".
I can't seem to find any spec sheets on this specific driver though? Does anybody know more about this driver, or have a copy of the spec sheet/pdf file?
Thank you
Okay, I don't have the data-sheet from Seas, so there must not have been one in the buyout process.
For those who bought them and want to know information, here is what I have attached. I ended up with 3 units, PE replaced one, as one had a rub in the voice coil upon arrival. Aside from that, it looked very similar to that of Sample 1. I have not yet taken an impedance of Sample 3. I would say that 1.8kHz is not out of the question, however, the frequency response I measured for these in this session is not the flattest, and they roll off pretty quickly. Since these were measured on the floor quasi-IB facing up with dense felt obscuring the transition from faceplate to floor, the FR will change a bit in a baffle, but it should not be drastically different.
The HD sweep is still valid relative to the fundamental as measured, but I would not compare them to other sweeps in different situations.
I hope it is useful for you.
Note- Sample 2 had the rub, but otherwise looked very similar. The measured HD is obviously much worse on that unit.
  • 29ttfcdg1.frd
    29ttfcdg1.frd
  • 29ttfcdg2.frd
    29ttfcdg2.frd
  • Seas 29TTFCD-G_1.zma
  • Seas 29TTFCD-G_2.zma
Reactions: Jean
