+/-24V (or thereabouts) 100-150W SMPS power supply
Yes, that's literally what the OP asking.
Personally, given it is a small amplifier, only 35W RMS, I would just get a 16+16 to 18+18 VAC 50 VA regular transformer, which is small, plus 4 diodes and a couple 2200/4700 uF by 35V caps and build a simple power supply.
Light, small and inexpensive, not worth going the SMPS route.
jm2c
At most, a 24-0-24 transformer, could blow amp.
Or find a 48V charger, common in solar, and split it.
35W is only 2 Amps, not worth SMPS, and transformer sound will be free of harmonics.
Meanwell is famous in SMPS, and there are many others in that line, but like JMF above says, transformer is enough, simple, good performance.
I got 24volt 6.5 ampere Meanwell smps for five euro from a bargain offer.
Took ten of them for several projects with small class D amps.
Its so difficult to find affordable transformers in germany. They are sold expensive.
The said 50VA 18 0 18 would cost 20 to 30 euro. And then you need an extra housing.
But for projects with small class D amps where one costs below ten euros I won't spend too much on a bulky power supply.
That's the point, a good SMPS shouldn't be that noisy (and at most you can add some large-ish cap on the power rails to further filter the noise, plus regulation for the preamp). A linear power supply can be more expensive than an SMPS (I was looking more at 100VA, honestly, because a guitar amp, contrarily to a hi-fi amp, is often operated at high volumes).
Quote: you can buy two 0-24vdc smps bricks and stack them up, this is how i do my amps...
I am thinking the “center tap” cannot be used to the ground of the amp, as the CT is at 24V . Could you just get a 48V supply?
