[3D Print] BJT Simple Matcher - Air Current Shield
Joined 2014
Attached is a 3D print file for a little box to be used as an air current shield when matching BJT transistors using @Mark Johnson 's BJT Simple Matcher.
Very simple design, but it fits snug and helps with consistent measurements.
This part will be included in all of the BJT Simple Matcher kits that are posted up in the swap meet.
Added thicker walls to minimize thermal transitions that I was seeing with the thin walled version.
