I am planning my first 4-way build and am struggling with the choice for the mid-bass to mid crossover frequency. The crossover is active, so I have a wide choice of parameters like baffle step, time delay, parametric EQ as well as the usual gain, frequency, phase etc. The drivers are 2x8" woofers, 6.5" mid-bass, 4" mid, 1" ring-radiator.
I am comfortable with 100 Hz low bass to mid-bass and 3.5 kHz mid to ring-radiator but I am in new territory with the mid-bass to mid transition. I have provisionally chosen 350 Hz for no other reason than the woofers and mid-woofer have good behaviour around this frequency. The relevant drivers are from the SB Acoustics range, SB17NRX35-8, SB12NRX25-8. The closest commercial speaker to what I have planned are the NHT 2.9 (no longer in production) but with slightly different bass alignment (sealed dual-forced opposed 8" in place of sealed 10" boundary re-inforced). If anyone has suggestions for the mid-bass to mid transition, based on actual experience and acoustic principles, I would be glad to hear them.
You would be better off with a 2" dome mid than a 4" cone in such a 4 way setup and cross it higher plus a 3/4" tweeter.
I am still tweaking my 4way with HiVi planar tweeter, 2x 2"Dayton domes, 2x 6" Dayton mid bass, and one (for now) 15" woofer. I have selected 150, 800 and 4k.
With only minor modifications its already singing beautifully.
There is, for good power response one would want the unit to not lose spl off-axis in larger quantity to keep the even response in that respect as well.
Exactly!There is, for good power response one would want the unit to not lose spl off-axis in larger quantity to keep the even response in that respect as well.
beaming
Forgot the link...Troels has quite a lot of good info on his page about crossover fr selection...
Design-Criteria
Rajneesh do you have any link to the build?
Thanks!
Floor bounce may be another factor. Where are your bass and mid-bass drivers positioned on the baffle?
- 4-way mid-bass to mid crossover frequency
