I would like to build Naim Nap 140 Clone. However I don't have schematic of regulated to transform 32-0-32VAC to +/-40VDC. I plan to use 7.125Amp of Transformer. I think LT1083 can handle it. Can any one provide me picture of schematic to built this amp. Thank you very much
Have you searched in "power supplies"
Power Supplies - diyAudio
This is probably where this post should be moved to.
From 32-0-32VAC you will probably get +/- 44V...is the amp OK with that?
This one should do it.
http://www.diyaudio.com/forums/powe...utput-adjustable-stabilized-power-supply.html
32VAC when bridged shall be 45VDC and I don't have diagram to drop it from +/-45VDC to +/-40VDC. Does any one has diagram of using LT1083 to drop the voltage. Thank you
The PSU I linked to is adjustable. It will do +-40v from 32-0-32vac. There is a schematic in the first post.
