6X4 Tube rectifier.
Hi!
I use the 6X4 as a rectifier in a hybrid bridge (with two BY 127 Si-diodes) in the power supply of my preamp, who takes about 50 mA at 300V. Rectifier input voltage is 450 V AC. From the tube's cathode, there goes a NTC resistor (ca. 300 Ohm cold, a few ohms hot, to reduce startup current) to a 50 uf electrolytic, a 5 H choke, another 50 uf cap, and then into the first regulator tube, a PL 84. Voltage reference is a TAA 550 temperature-compensated precision zener voltage source (33 V).
I built this amp in the late 80's, and at the moment where I am writing this posting, it has run 22,869 hours.... (I have a counter in the PSU....😉 ), always with the same tubes.... This also applies to the PL 84 / PL 95 / PCF 802 in the 2-stage regulated power supply....
So far I don't see any signs of weakening of the tube(s)....
Don't know how much you'd charge the tube, but with the above data you easily could expect about 8 years of 8 h daily service.... (23,000 : 8 : 365)
Uli
Re: How much current
SINGLEENDED said:
The pre amp. consume 250vdc @ 100ma.:angel:
indeed, like Eli said, this even exceeds the ratings of the next bigger tube in this row, the EZ 80. (rated for 90 mA max.). And I prefer running the tubes not at their limits, especially not rectifier tubes. Forward drop increases quite much when running them close to their limits. So indeed take a EZ 81, or, if you can provide for a separate 5 V heater supply, the GZ 34 (5 V, 1.9 A heater (connected to cathode), EZ 81 is 6.3 V, 1 A, heater isolated from cathode) and has at 100mA only a few volts forward drop. EZ 81 has 15 V there, GZ 34 only 8 V.
Uli
Re: Re: How much current
Uli
I have a couple of EZ81 brand ultron ,3pcs of GZ 34 rca , 6X4 tungsol , 6X4 raytheon , 6X4 ge, and trying to get my hands on Haltron if you can help.
Why 6X4 ge and at their peak limits. 1, it is very quiet . 2, it is not pushy compare to others, 3, open soundstage. .
Btw the preamp is feed from oil bath trans supply.
Brands.
Brand does not make the sound.
Different manufacturer make their tube differently.
I like GE & Haltron they sound open and warm.
JJ is not so good I have a few pieces.small sig.
Yes it is feed directly from the high voltage line.
And yes it really make the whole set up sound different. Very quiet i should say.
