I know that this topic should be propably in "Instrument amps" forum, but this forum is more relevant because of the design and designer.
I would like to tweak the ACA amplifier for mixed-mode feedback to better mimic tube amplifiers.
I don´t know if I have connected correctly the feedback paths and how to calculate the resistors with question marks to obtain same voltage gain to the 8R load as original - 14dB of gain.
I have found some document how to calculate resistors values for mixed-mode feebdack, but don´t know how to appy it to ACA topology
Thanks.
Thanks.
I think I have it done. I have simulated schematics in Multism and both types of feedback are set to reduce total gain evenly, they are mixed in 50 to 50 ratio. Closed loop gain of the amplifier is unchanged - 5x. Don´t know how much output impedance is raised.
Latest schematics
here is the latest schematics of Amp Camp Amp modified as guitar power amp.
Apart from little tweaks I have added presence filter control as many guitar preamps do not include it. For more bass increase 1uF after opamp. It sounds great!
Enjoy.
Enjoy.
