Accuphase M6000
Accuphase M-6000, a MOSFET class AB amplifier made between 2008 and 2015.
On its prospectus it said A damping factor rating of more than 500 demonstrates that this amplifier is capable of driving even the most difficult, ultra-low impedance loads with ease.
Weighing in at 38kg, and Continuous Average Output 1,200 watts into 1 ohm (✽)
600 watts into 2 ohms
300 watts into 4 ohms
150 watts into 8 ohms
  • Two totally identical power amplifier circuits driven in parallel
  • 16 parallel push-pull arrangement of MOS-FET devices in output stage
  • Input stage configured as double instrumentation amplifier
  • Double MCS+ circuit and current feedback topology in amplification stage
  • Support for bridged use of two M-6000 units with even higher output power
  • Power supply with massive high-efficiency 900-VA toroidal transformer and large filtering capacitors
When I googled a week ago I couldn’t find any in-depth review. Probably not too popular.
I wonder how it sounds compared to the Pass labs A5.
