Adcom GFA-5800 wattage question
I am going to apologize upfront if this is a super simple question, so please bare with me.
What I am looking to do is a bias check/adjustment (in necessary). According to the service manual, below is the first step of the procedure.
"With amplifier connected to 8 ohm resistive load, apply a 1khz sine wave at the input to achieve 83.3 watts at the output."
So my question is, is there a formula for finding out what values I would need to calculate to find the wattage value?
I know the voltage will be between 115-120, but I do not know what my current would be or where I would check for it. I have attached the pdf if anyone is interested and sorry for the crazy question.
Side question, anyone know a decent 8 ohm resistive load that does not break the bank or do a lot of folks here make their own.
Thanks.
Power = Vsquared/R, therefore V = Square Root (Power x R)
With an 8R load and 83.3W, V = Square Root (83.3W x 8R) = 25.8V
So with an 8R resistive load on the amplifier speaker output, 25.8V across the 8R load will be 83.3W output.
For a reasonably priced resistor load, mount two 4R 100W resistors on a heat sink.
Example of a thick film non-inductive resistor: 100W 4R non-inductive resistor
Reactions: exojam
