Hello everyone,
I am pretty much new in Class D amps and I am new on this forum as well. I have seen many interesting things here but I didn't find exactly what I wanted.
I have found some Class D amplifier kits from Sure Electronics but they are all with analog audio inputs. What I would like to do is to modify them to have digital inputs like spdif coaxial optical, aes/ebu... I want pure digital amplifier without converting to analog. Is there any way to do this and how would it be?
Here is the board I would like to modify... for example.
Sure Electronics' webstore 2 x 250Watt Class D Audio Amplifier Board - IRS2092
Best Regards.
Best Regards.
Get a DAC, D in Class D does not stand for Digital, it's a type of analog amplifier (switching).
Thanks for reply. I do know this. In the case, analog is being converted to PWM. I would like to convert digital to PWM and avoid using classic DAC. Is this possible?
Best Regards.
Ok! You must add a DAC.
No. As there is no exposed digital (PCM) interface in this product.
The board is based on a IRS2092 which is a circuit that only has one input "In", described as: Analog inverting input.
http://www.infineon.com/dgdl/irs2092.pdf?fileId=5546d462533600a401535675f1be2790
There are almost no "pure digital amplifiers" on the market. The ones that claim this still go PCM (digi)->PWM (ana)->ClassD (ana).
Some like to call the "PWM (ana)" stage for "semi-digital" or even digital:
http://www.diyaudio.com/forums/class-d/296951-class-d-amplifier-resolution.html
Thanks for reply. There are several models from them but I don't know how to choose... I don't know how to recognize one which can be modified to what I have mentioned above. 🙁
Hi, if I read correctly you want an FDA (Full Digital Amplifier). Just adding a digital interface to a class D amp won't work as other mechanisms are needed. You don't want a DAC as a DAC converts digital to analog, then you have to amplify analog signals again. I think you want to keep it in the digital domain till the power stage. Some call it PowerDACs, some have a technology they call DDX. There is unfortunately not a standard name for it although FDA seems to stick.
One of the cheapest complete and ready built devices is the FX Audio D802. There is a D802C but it is not as good. Has bluetooth which pollutes the device. The D Sound D310 is an example, the Topping VX2, the I. AM. D V200, Nuforce DDA-100, Nuforce DDA-120, QLS QA-100, Alientek D8 and many other solutions with STA326 chips.
If you want to partly DIY then look here:
http://www.diyaudio.com/forums/class-d/299007-modding-taobao-digital-amps.html
Yes, I want FDA. I have considered D802C and thank You foe this info about bluetooth. Anyway, I need something more powerful and I like to modify. I am not sure now much I can modify this kind of amps (like D802) to achieve more power.
[/url]
Which one would You suggest between cheaper ones? D802, Alientek D8, I.AM.D V200 or TAKAS A50? Its hard to decide as they are all similar.
Best Regards.
- Class D
- Adding digital interface in class D amp
