Hello , I am getting back into vinyl and have an adcom gta-555 mkII set up with the gtp-450 pre amp. I also have a second gta-555 mkII on the way. I am thinking of bridging them if all works out. I will be using a set of Polk Audio RTi10 that I pulled from my home theater. I also have access to a nad 1300 pre amp, which has a phono stage.
I would like to keep tuner capabilities and was wondering if there is anyway I can hook the nad 1300 pre amp to use the phono stage in line with the adcom gtp-450?
If I bridge the power amps can I hook a preamp to each power amp and turn on the pre amp to what I want to listen too be it the tuner pre amp gtp-450 or phono pre amp nad 1300. Thanks in advance
You should be able to feed the NAD preamp output directly into any of the Adcom preamp inputs, including the two tape inputs. I would use the 'normal' rather than the 'high' output of the NAD, at least at first to test.
