I have CD player Advance acoustic MCD 203.
I have a problem with open/close door mechanism,
When i push the open/close button doesnt open
only shows in the display OPEN or CLOSE
(any time when i push the open/close buton.)
*I checked the small belt on the drive/mechanism motor & its ok
**this motor doesnt starts when i push the open/close buton
What could be the problem?
Can be problem in the Power supply(capacitors..)?
or somewhere else... ?
any idea about this - for solution is welcome
or how to found a schematic diagram-service manual ..
thanks at all
thanks at all
MCD 203
Often there is soldering issues on the digital board behind the transport , possibly there can be a power supply issue but markings on the PSU pcb will guide you to see if all voltage is present .
Statistics though lean to soldering on the pcb . You need a reflow
Kind regards
Sakis
Kind regards
Sakis
