> AIRPAX 7914 203-22-1-64F-123-6-1-8
This is not just a switch. It is a circuit breaker, panel-mount, with lamp.
"7914" looks like a date code. Omit that when searching.
AIRPAX 203-22-1-64F-123-6-1-8 in Google turns up multiple hits. That is the part number. The only price I found is frightening.
https://www.onlinecomponents.com/airpax-sensata-20322164f123618a.html?p=10048105
Date "7914" looks like 39 years old. May be hard to find. I could not find specifications.
I think you want to measure the panel cut-out and look for a switch that size. If the equipment is operating properly, an internal-mount circuit breaker will replace the original Airpax breaker function. A light is trivial; today I would use an LED.
