AIYIMA A03 - TPA3116 D2
I meant adjust the knob first to see if it acts as a high-pass adjustment for the speakers. If it does, and all the way left still causes excessive bass roll-off, then a circuit modification would be needed to fix it. I can't help you if that is the case.
