Alpine ida usb to ipod cable pinouts?
This is correct, a normal USB cable won't work.
Here is a link that may help you:
Alpine USB iPod connection for iDA-x001,100,200,300 pinout diagram @ pinoutsguide.com
1.) The accessory detect pin (number 21) is connected to USB GND via a 191kOhm resistor. This resistor sets the iPod in "iAP over USB" mode.
2.) The AUDIO_SW pin is directly connected to USB GND. This internally routes the iPod audio to output on pins 3 & 5 rather than the 3.5mm headphone jack. I am not sure why this connection is made since no analog audio data from pins 3 & 5 is transmitted on the USB interface. It is however necessary for the interface to function correctly.
The pin N15 -(GND) should be connected to pin 16- (USB GND).
Using this guide you should be able to construct your own cable using a standard white USB interface cable available from ebay. Simply open up the iPod dock connector and solder in the resistor.
