Already have LT1085, should I switch to LM350AT?
I have a bunch of new, unused LT1085 regulators. I'm looking to build a better-than-average low noise, 5V / 3A linear PS. I have some circuit designs for the LT1085, but was wondering if the LM350 is a better regulator - lower noise across the audio band, better linearity, ripple rejection, etc - for use in a high end system. Or are these two outperformed by something better?
Reviving this old post, I don't even know if the OP still is interested.
I have an old Welborne Labs PS8 power supply board powering octal
Aikido, by some reason the pre has bad hum in the output. I tried to figure out what's going on while trapped in snow, and noticed that the 6V filament supply produces buzz even without any load. I don't know if this is the cause of hum in the pre output, but it's annoying by any means. Attached is the schematic, and the U1 is LT1085.
Does anyone know if this buzz is from LT1085 and I should replace it with LM350AT or something else?
I finally found out the problem. Welborne Labs PS8 board was purchased as assembled, and they did not insulate 1085 from the heatsink. That's not us amateur DIYers way, but maybe professional vendor's way?
I added insulation, and they are very quiet now.
