AMD tube integrated tube amp
AMD 36-110
Hello:
I happen to be working in an AMD 36-110 now. The amplifier does not have a schematic available. The unit has has all of the electrolytic caps (except the 40/40/40 @ 350V) replaced and some of the signal caps as well.
The amp now plays a 'distorted' 5 watts of Single Ended Power.
The tubes inside the amp are:
4x 6BQ5/7189 (Power tubes)
2 x 12AX7 (Input tubes)
1 x ECC85/6AQ8 (Driver tube)
1 x EZ81/6CA4 (Rectifier)
Can you confirm that these are the correct tubes? There are no markings on the amp, and the ECC85/6AQ8 tubes measures at a low 90 Volts on the plate. For a driver tube sounds low.
I would be happy to help you fix your amp in case it needs help.
BR/
Rich
