https://www.diyaudio.com/community/attachments/ground-scheme-3-antiparallel-diodes-jpg.336247/
Anybody can tell me the values of the resistor and capacitor?
Thanks!
Thanks!
Fender Reissue 63, have two 6A4 + 15Ohm resistor, nothing else.
https://schematicheaven.net/fenderamps/63_reverb_manual.pdf
Indeed, and their construction should be of the metallurgical bond variety: https://www.microsemi.com/document-...allurgical-bond-evaluation-methods-for-diodesTypically something of the order of 220 ohm and 100 nF. More importantly, the diodes have to be big rectifier diodes to ensure that they don't fail open at current levels high enough to blow up a mains fuse of the house.
These types always fail as a short, except if the current is sufficient to make them vaporize and explode, which requires a significant energy.
Metal-case types like DO203 look very sturdy, but they have a bonding wire that can act as a fuse, given a sufficient current (or I²time, to be accurate)
