I just bought a carver pm 1.5 to hook up to the xlr output of my Nad dac/ preamp-im running a set of Magneplaner 2.7qrs and apparently the more power the better-anyone used one of these or something similar? from my limited understanding the pm 1.5 is similar to a lot of bob carver's models
I used to use the PM 1.5 /Adcom GFP-750 in passive mode to drive my Martin Logan CLS Z2… no complaints ie: sounded very good to me and my speakers are considered difficult to drive…the fan can be noisey though.
Yes,
I drive my bi-amp'd homebuilt hybrids and subs with a trio of Carver TFM-25's (225W/Ch) amps. However, a friend whom I built an identical pair of hybrid ESL's for, drives his with a Sunfire 400 X 7 (400W/Ch).
The Sunfire sounds great and has tons of power!
Using a modified Sunfire 300/2 on Apogee 1 ohm Scintillas and runs cool as a cucumber and left on 24/7
Imagine doing that to almost any other amp
Is it the best amp out there ? I would have to say no but it has a smooth balance of strenghs and overall a fun amp
combination to listen to over time with insane power and doesn’t cost a fortune to operate
I just added a Carver m 4.0t into 3.7i maggies. Had an NAD 2400. The higher power seems to control everything better.
I've run the infamous Infinity RS 9 Kappas (sub 1 ohm dip at 37hz) with a single Sunfire 300 and it never even got warm.
I have been using carver 1.5 t for many years to drive me Acoustats with full sound stage and clean sound. About 15 years ago I started to use macintosh mc600 and then 12 years ago went to the Sunfire signature grands 5 channel 405 watt per channel and never have had a second thought and enjoy the clean neutral wide sound stage with a pair of 1 ohm scintillas where the amps never broke a sweat. I have been using the Sunfires with my Spectra 6600 2 plus 2 etc and the second Sunfire with a pair of Soundlab A1 PX.
We used one of the original Carver cubes to drive Magnepan’s. Rated at 200w it audiably clipped into the quite resistive load, sooner than the 20w NAD 3020. I think it was the only one we ever sold.
dave
dave
Clearly a malfunctioning amplifier. You didn't bother to troubleshoot it and/or send back to Carver???
Dave.
Dave.
No, functioning perfectly fine. It was bench tested.
Just shows how important the nature of an amplifiers clipping is.
dave
dave
You understood how those amplifiers worked, yes? The two channels being opposite polarity, and all the other idiosyncrasies of that design???
Dave.
Dave.
I Used a M400t cube Carver amp for 15 years to drive my old Dahlquist DQ-10s. Worked fine. I do think the combo had a slightly smaller sound stage than normal, yet very 3D and accurate.
I use a Sunfire 300 on Acoustat 1+1 electrostats. It barely gets warm after listening for hours. The dynamic range is better than my Hafler 9505. The Hafler is smoother sounding, but the Sunfire is more revealing of detail.
I not sure of the genererations of the Carver Cube, but the first generation was a disataer on Accoustats, Hafkler wasn’t any good either.
dave
dave
I owned a Carver Cube 400a for a couple of years. This was the 'A' version so I assume a lot of the issues with the first version were fixed. I experimented and drove PA cabinets with it, it didn't compete with a Crown DC300 we had but it got loud on midrange cabinets, never tried it at a gig though. A friend has a Hafler DH500, it always struggled with his Acoustat 1+1 electrostatics. I loaned him my Hafler 9505 and he didn't want to give it back.
- Planars & Exotics
- Anyone use Carver or Sunfire amps with their electrostatics or maggies?
