Apogee Jam DIY cable to USB
Hi I just bought an Apogee Jam on ebay and it come without cable whatsoever 🙁 I looked up and it's a proprietary connection which Apogee charges a whooping 24.99 for each cable and ideally you would need 2 or three depends on your needs (Lightning, USB A and USB C) - I think this is way too much for a USB cable so I opened the JAM and looked inside. There is a 10 ways jumper and the connector is very tiny soldered with maybe 10 cables going in... Knowing that USB A is only 4 cables I would be happy if I could make a cable, I don't mind to solder directly on the board.
Does anyone happen to know what the connections are?
would it be possible to solder the cable direcly from the jumpers maybe?
It's a shame otherwise as I can't afford to buy a cable at those prices and you can't find on ebay as it's quite rare and proprietary 🙁
I read somewhere that's the same cable as the Apogee Mic,
any help will be gladly apprecited, thank you
Stay Safe
Stay Safe
I am in the same situation as you, bought an Apogee Jam but no cable for it.
Did you get a cable pinout/schematic?
