Are BUV20s double-die?
Ahhh... so that's why the SOA curve has that funny inversion in it.
I wonder if this fit in with Vereker's dislike of parallel output devices: it essentially operates as a single device until the current demands rise, at which point it becomes two. Or if he was just unaware of this.
All switching transistors have a funny inversion in the SOA curve, regardless if they are double die or not. Even a lot of the higher speed FETs do now.
I think all the Motorola 50 amp TO-3 devices with the large pins are double die. Even the darlingtons, even the low voltage ones specified for linear operation. And you do not get a full doubling of the SOA, or even current capacity. Two 30 amp 200 watt die are needed to get 50 amps at 300 watts. And the second breakdown point comes back a little. Not only that, but the prices are pretty high so you might as well use two of the single die version. At least in an amplifier.
